Asus A52F bios dump needed
  • Scootie
    • Feb 2014
    • 133
    • Romania
    Hi there,
    I bought of someone this laptop, previous user used it in the bed so the pch heated so much that it melted the plastic around. I replaced the pch with a new one but the laptop wont even start up now. I read somewhere that bios needs a new flash to have a video signal after a replacement. I found the bios on asus site but its only 2mb vs the original one which was 4mb. Also had problems writing it it to the bios chip. Using my programmer and selecting w25q32bvs @ioc16 the chip could be erased but not written(error at finale) so I had to use w25q32bvs @ioc8. Still, the laptop wont even fire up. Anyone has a working dump for this laptop?
    MB: K52F Rev 2.2.
    Thanks.
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Asus A52F bios dump needed
    backup your old bios and try this
    if your fan runs at 100% i need your old dump to fix that
    Im Back... sort of...
    • Scootie
      • Feb 2014
      • 133
      • Romania
      Thanks for the answer, atm, im hooked up on quite a few priorities but I will try your bios to run tomorrow.
      • brainles
        • Nov 2012
        • 2
        • romania
        Dump is good, works for me. Thanks ala_borbe.
        • Scootie
          • Feb 2014
          • 133
          • Romania
          Im still working on my own. Tried some version not sure if yours but will get back as soon as I have some results.
          • anno
            • Sep 2007
            • 140
            • netherlands
            i have Asus K52F-EX575V with bad bios flash. So this dump should work?
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              read and backup org bios, even if not working and try this then
              • abdulhalim933
                • Oct 2015
                • 14
                • damascus
                thanks man
                • 789852
                  • Nov 2015
                  • 51
                  • Kazahstan
                  thanks
                  • Bybuca35
                    • Apr 2017
                    • 11
                    • VVVvvv
                    thanks
                    • hws002chris
                      • Feb 2015
                      • 3
                      • Philippines
                      Very Appreciated.. 100% Working ..Thanks
                      • magdi80
                        • Jan 2017
                        • 7
                        • syria
                        X52f rev 2.2 bios dump needed
                        • magdi80
                          • Jan 2017
                          • 7
                          • syria
                          Re: Asus x52F bios dump needed
                          • Scootie
                            • Feb 2014
                            • 133
                            • Romania
                            After 2 and a half year I found this dusted abandoned project. Created a Clean ME bios out of the uploaded file and it fired up on the first try.
                            Thanks.
                            • linterna
                              • Nov 2013
                              • 0
                              • mexico
                              Thank you
                              • alejopat
                                • Feb 2014
                                • 1
                                • Colombia
                                Hi, i have the problem of fan at 100% and then after a 2 minutes aprox, it turns off machine. in my asus k52f rev 2.2, what can i do to fix this problem, im' would be so greatfull if you can helpme, thanks. I have a copy of the original bin
                                • Vesko356
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  Become a Badcaps supporter
                                  Thanks to all supporters.​
                                  • DynaxSC
                                    Need real mobo dump of BIOS v402 for ASUS PRIME Z590-A - stock image no help
                                    by DynaxSC
                                    I have a serious problem to program the Z590 chipset SRAM with a Management Engine after replacing the chipset.
                                    The new chipset is factory new and is not containing any Management Engine. Any attempts to program it into the chipset under Windows ends with a failure (eg. Error 20: Management Engine Device not present, or something similar).
                                    Due to the lack of the ME several ports on the board, including all M.2 ports aren't working, booting OS works only on USB. So it's now other way, as to program the chipset with a ME.
                                    Usually on ASUS boards it worked...
                                    06-14-2024, 03:49 PM
                                  • DynaxSC
                                    MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                                    by DynaxSC
                                    Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                                    I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                                    11-17-2023, 10:56 AM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • TacticalFahrrad
                                    [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                    by TacticalFahrrad
                                    Hi everyone,
                                    I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                    BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                    I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                    06-30-2025, 04:09 AM
                                  • vinaypundith
                                    Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                    by vinaypundith
                                    I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                    So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                    08-03-2024, 12:32 PM
