Ego 56V battery charger dead
  • braxton
    • Nov 2009
    • 146
    I would like to try to repair an Ego brand standard 56V battery charger. The model number is CH2100.
    There is a brief YouTube video on it here:
    https://m.youtube.com/watch?v=2cYAKUuVgUE
    The charger appears to be completely dead. Upon disassembly I found the glass fuse is ok. The only visible damage was a completely blown ceramic capacitor behind the two largest caps.
    I am attaching a few photos with arrows to the location of the blown component.
    I'm hoping for some suggestions as to what might have caused the cap to blow and how to troubleshoot further.
  • petehall347
    • Jan 2015
    • 4437
    • United Kingdom
    Re: Ego 56V battery charger dead
    see if its shorted and check whatever its connected across ..might be a fet .
      That is a snubber cap connected in parallel with Sourde and Drain pin of the MOSFET. Can you still read what is printed on the cap?
      You also need to check the Low Ohms resistor connected between the Hot side circuit ground and the Source pin of the MOSFET to make sure it is not blown open circuit when that cap shorted out, if that resistor is blown the SMPS IC that drives the MOSFET can be damaged also.
      Did you check the resistance between Source and Drain pin of the MOSFET after removing the blown cap?
      • braxton
        • Nov 2009
        • 146
        The Cap was blown pretty badly so could not read what was on it. I think it might have been a 2.2nf 1KV cap. I replaced it with a 2.2nf 250V cap but still no life from the charger. It does not appear to be shorted across the 2 pins of the cap. The 2 outside contacts of the mosfet seem to have continuity though.
          1) That cap has to be at least 1KV rating, more likely that it is 220pF 1KV but I would use 2KV since this is commonly failed cap.
          2) What is the exact resistance do you get when measure between Source and Drain pin? You do know what each pin of the MOSFET is correct?
          3) Did you check the Source pin resistor as I suggested?
          • braxton
            • Nov 2009
            • 146
            The mosfet is 18n65. I had to remove it to get the number.
            There is no continuity between the center leg and both outer legs.
            But there is continuity between both outer legs on the fet.
            Resistor R52 (large resistor closest to blown cap) has a reading of 5.7k when removed from the board.
              I cannot see R52 on the top side of the board due to the picture is not clear enough to read the designators as printed on the board.
              Show us good clear pictures of R52 and where it is located on the board. Source resistor should be < 1 Ohm.
              "But there is continuity between both outer legs on the fet." What is the resistance reading using Ohm mode?
                https://www.badcaps.net/forum/attach...5&d=1594741646
                What is the P/N of the SMPS IC U9?
                • braxton
                  • Nov 2009
                  • 146
                  I’ve attached a few more pics of the resistor I tested. Shown with yellow arrow from the top of board and purple x’s from the bottom. Yellow x’s and red arrow on bottom of board are the location of the blown cap.
                  It’s not possible to read anything on the top of u9 unfortunately.
                  • braxton
                    • Nov 2009
                    • 146
                    Resistance reading on two outer pins of the fet is 1.4 ohms- same reading when I touch two leads of multimeter together.
                      Well that means you have shorts between Gate and Source, remove the that MOSFET and retest it off the board.
                      More than likely that U9 is damaged too.
                      What is the color bands of the R52?
                      BTW, you have have to try cleaning the top of IC with Alcohol to see if you can read the prints on top of it.
                      • braxton
                        • Nov 2009
                        • 146
                        I tried gently scraping the coating off and using alcohol on the U9 chip but still could not read anything. At one point I thought I could read the number 28 but not sure.
                        Here is a picture of the resistor. The color bands appear to be brown-grey-silver-gold
                        • braxton
                          • Nov 2009
                          • 146
                          Also, the mosfet was tested after removal from the board, and was shorted on the outer pins.
                          In the you tube video I posted in the first link, in the comments section, someone indicated they had a defective C30 (same blown cap) as well as a blown Q16 and D22 (close proximity to U9), but the latter two components don’t look blown on my board.
                          • braxton
                            • Nov 2009
                            • 146
                            Its possible the U9 chip might have the following written on it:
                            28600D
                            96M
                            A6N2
                            • braxton
                              • Nov 2009
                              • 146
                              would this be a suitable resistor replacement?
                              https://www.digikey.ca/en/products/d...mSeq=332340179
                              • braxton
                                • Nov 2009
                                • 146
                                I salvaged a 0.22 ohm resistor, 417pF 2KV cap and a 12N60 fet from some scrap boards, and got the charger to come to life with the lights lighting up and no bangs or poofs of smoke.
                                Probably will not test further until I order the proper parts from digikey.
                                  0.18 Ohm (Brown/Grey/Silver)
                                  • braxton
                                    • Nov 2009
                                    • 146
                                    Well it's working fine and charging with my franken-parts installed.
                                    I am debating whether I should even order replacements. I suspect the cap and resistor will be fine; less sure about the fet since its rated for 12A and 600V vs the original 18A 650V.
                                    • braxton
                                      • Nov 2009
                                      • 146
                                      Thanks budm for helping me identify the parts that needed replacing.
                                      • !sense
                                        • Dec 2016
                                        • 14
                                        I have the same issue and have noted similar damage to the same components.
                                        I'd also like to pursue fixing it - should I continue on this thread to create a better repository of information on the Ego charger or would a new thread be better?
                                          ISL88739AHRZ ISL88739 Laptop Battery Charger Datasheet
                                          The ISL88739 & ISL88739AHRZ are a highly versatile combo battery charger
                                          configurable for operating as either a Hybrid Power Boost (HPB)
                                          charger or a Narrow VDC (NVDC) charger, supporting 2-, 3-, or
                                          4-cell batteries. Both configurations allow the battery to work with
                                          the adapter together to supply the system load when it exceeds
                                          the adapter capability, referred to as system Turbo mode. HPB
                                          charger configuration reverse-boosts battery energy to the system
                                          bus to help the adapter provide the system power in Turbo mode.
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                          Narrow VDC applications where the system power source is
                                          either the battery pack or the regulated output of the charger.
                                          This makes the max voltage to the system equal to the max
                                          battery voltage instead of the max adapter voltage. Operating
                                          at lower system voltage can improve...
                                          11-05-2024, 04:43 PM
                                        • flat-earther
                                          how to prevent a connected charger from draining battery when not charging?
                                          by flat-earther
                                          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                          So the battery is backfeeding the charger and being drained.
                                          How can I prevent...
                                          08-07-2025, 01:04 PM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                          Bauer tool battery pack charging with a HERCULES charger modification
                                          by sam_sam_sam
                                          The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                          Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                          05-06-2023, 12:17 PM
