CDROM Drive bad cap?
  • Mustang
    • Dec 2003
    • 203
    220uf 16v bulged. This cap has a diamond logo with BH inside. All other caps are Tayeh and look fine. I was under the impression all caps 470uf and under aren't prone to the plague.
    The drive is a Creative Labs CD5230E.
  • Rainbow
    • Aug 2005
    • 1375
    Re: CDROM Drive bad cap?
    Crap everywhere...
    • AK0R
      • Mar 2005
      • 204
      They just haven't been observed to have failed much, because most of the load on motherboards and power supplies is carried by higher value caps (1000uF and up). There are several posts relating problems with Choyo 330uF caps. I have an audio card (Creative Labs SoundBlaster PCI512) that I need to recap that appears to have bad Jamicon and WinCap caps, values between 4.7uF and 100uF. No visible leakage or bulging, but several are pushed up off the board 1 or 2 mm.
      • linuxguru
        • Apr 2005
        • 1564
        I've seen bad caps on soundcards (GSC mostly) as small as 100 uF. The bulge may not be obvious, but there'll be a small discoloration at the center of the non-vented caps. I've also seen visibly bulged and vented 470 uF caps (again on soundcards - maybe the speaker cables shorted).
        • linuxguru
          • Apr 2005
          • 1564
          BTW, Tayeh are also crap - they usually fail quietly without bulging and venting, similar to Choyo and G-Luxon. It may not be an issue in a CDROM drive, but the motor drive circuit takes a fair amount of current during spin-up.
          • AK0R
            • Mar 2005
            • 204
            This was on the first BE6-II that I recapped. It's running a 700MHz (100MHz FSB) P3. Just to see if it would work, I bumped the FSB to 133MHz. The PC booted just fine, but couldn't find the sound card (AGP video, HD, keyboard, mouse, ISA fax/modem all OK). So, I put the FSB back to 100MHz. The PC would sometimes detect the sound card, usually not. Got another sound card to replace it, which made my 7-year-old happy (it's his computer).
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              that is remarkable, thanks for posting indeed. is the cap causing any issue with the drive?
              • Chris1992
                • Apr 2005
                • 561
                >[Tayeh] usually fail quietly without bulging and venting
                I have 2 1500@6,3 Tayeh on Soyo Super 7 board bulging.
                The great capacitor showdown!
                • Mustang
                  • Dec 2003
                  • 203
                  The drive has been running fine. I took it apart for a cleanup before sending it off to a nephew's pc. Been debating whether it's even worth the expense of a recap or just let it c(r)ap out on it's own. The closest value caps here are either 470uf 10v or a 1000uf 16v.
                  • japlytic
                    • Oct 2005
                    • 2086
                    This "BH" capacitor is Bor Hurng. This capacitor failure was most likely to be caused by a power supply with inadequately rated electrolytic capacitors on the output side, so the capacitor on the CD-ROM drive had to work harder...
                    • Mustang
                      • Dec 2003
                      • 203
                      That would have been one of my Antec's. Not sure which one but they all had bad caps. Interesting how 1 bad component can really wreak havoc on the rest of the system.
                      • lordoflove
                        • Feb 2006
                        • 1
                        i need u help can u tell me how i repair cd rom
