00165 - 2.7V on SMC RESET L
  • BrickBreaker
    • 52
    History is "Coffee spilled on keyboard. Dim apple logo for a while now dead." There was liquid damage on backlight driver, surprise. BIOS, RTC area was also hit, pgood guy Q8150 and U1950. Also damaged was U5600 but not liquid, more voltage surge.
    I have replaced BIOS chip, U1950, U5600, R7121/2
    Currently
    3v3_s5 - 3.3v
    3v3_sus - 3.3V
    RTC G3H - 3.3V
    5v_s5 - 5.1V
    5VS4RS3 - 0v EN - 0v
    SMC_PM_G2_EN - 3.4v
    SMC_RESET_L - 2.77v
    I'm a little foggy on the exact order and dependency of SMC, PGOODs, RTC Bios.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: 00165 - 2.7V on SMC RESET L
    Green light on Magsafe?
    Double check SMC_RESET_L. If it is really 2.77V instead of 3.42V, check for any liquid corrosion on J6100. If that's not it, you may have an issue with R5100, U5110, U7100 or SMC.
    (Usually 2.7V is found on SMC_MANUAL_RST_L, not SMC_RESET_L.)
    Measure exact voltage on PPBUS_G3H.
    Also, SPI ROM almost never dies. The resistors and traces do. Put the original one back, or at least use the dump of the original one on the new chip.
    • BrickBreaker
      • 52
      SMC_RESET_L is 3.39V
      PPBUS_G3H - 8.60V
      • BrickBreaker
        • 52
        It's SMC MANUAL RST that's low, but isn't it normally 3.4V on a working board?
        • piernov
          • Jan 2016
          • 4439
          • France
          Nothing to see there then, everything is fine. I assume green light is present.
          Missing PM_SLP_S4_L then I guess?
          Check if there's at least a pulse on in when plugging Magsafe in. (use oscilloscope if your multimeter is slow)
          Make sure PM_BATLOW_L is high.
          • BrickBreaker
            • 52
            Light on charger is present. Green at first, Amber b.c no battery.
            PM_SLP_S4_L pulses, multimeter caught it go up and back down. Missing while powered.
            PM_BATLOW_L - 3.315V
            • piernov
              • Jan 2016
              • 4439
              • France
              Check if CPU VCore pulses too. If it doesn't, check for a pulse on ALL_SYS_PWRGD and PM_PCH_SYS_PWROK.
              If CPU VCore pulses, you most likely have an issue with SPI ROM, or SPI resistors and traces (or stuff on J6100).
              If CPU VCore and PM_PCH_SYS_PWROK don't pulse, but ALL_SYS_PWRGD does, you have an issue with U1950 circuit.
              • BrickBreaker
                • 52
                I measured a pulse on CPU L7310 and then when I plugged in power to measure for pulse on ALL_SYS... fan spin.
                • BrickBreaker
                  • 52
                  Ok it's back to not working, L7310 is definitely pulsing, I also measured a pulse (sort of) on PM_PCH_SYS_PWROK but the fan spun that time, and it looked like the rail only reached 0.116V? Going to try and get a read on ALL_SYS_PWRGD. I am one handing the probes so I don't think I've gotten a good read.
                  • BrickBreaker
                    • 52
                    Thank you for your help, I'm sure I'll look back at your wisdom from this post in the future.
                    I must be on the right path if it's turning on while I'm probing that circuit. I will post what the problem was if I find out anything.
                    Probably about to do a little replacing (new ISL since I used a donor, lifting U1950/continuity checks, probably should change Q8150)
                    • BrickBreaker
                      • 52
                      It was pgood, Q8150 was lifted/ one pin not connected.
                      • sheffieldyorky
                        ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
                        by sheffieldyorky
                        Hey there people
                        While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
                        This is what I tried, but not in any order.
                        Google
                        YouTube
                        BIOS
                        Command Prompt (administrator privileges)
                        On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
                        Yesterday, 02:22 AM
                      • odie34
                        Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                        by odie34
                        I am a hobbyist (not a professional) so please be gentle...
                        I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                        I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                        02-18-2024, 09:11 AM
                      • ictc
                        Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
                        by ictc
                        I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
                        Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
                        The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
                        02-25-2025, 12:15 PM
                      • kotel studios
                        ASUS M5A78L-M LX - PWR button works sometimes, CPU stuck in reset
                        by kotel studios
                        Firstly I'd like to apologize if this was posted in the wrong forum (I'm new here )
                        Recently I got an ASUS M5A78L-M LX board in a scrap lot. Saw one broken cap which I've replaced. No broken traces and missing components. While soldering a new cap a bit of solder got onto components bellow SB (opposite of the two lythic caps). Didn't see it and powered the board on.
                        I was greeted with it not starting. Came back to it a day later and shorted the PS_ON with GND to force it on. It sprung to life but with CPU stuck in reset (it was an FX 4600 I believe). Thats when I saw the...
                        12-14-2024, 10:48 AM
                      • MyBrainIsAStrainer
                        Asrock H87-Pro4 Rev. G/A 1.04: Power cycling on reset only
                        by MyBrainIsAStrainer
                        Hi!
                        I have a weird one for you. I have a H87-Pro4 from Asrock that power cycles. But only when you do a restart after it was already running!
                        Symptoms in detail:
                        1. I switch off the ATX PSU for ~15-20 seconds, then switch it back on again.
                        2. I press power button. The board boots without issues.
                        3. I can shut down the board any way I want (via OS* menu, or pushing the power button - either in the OS or the boot manager).
                        4. Push power button again, board boots fine.
                        5. This shutdown/powerup can be repeated multiple times without problems.
                        6. BUT: If I do a restart instead
                        06-25-2023, 02:44 PM
