Panasonic tc-p65s2 dead 10 blinks
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic tc-p65s2 dead 10 blinks
    Originally posted by rageed
    finally able to get back to this !!! thanks again Tw2005 for all your great help !! just want to clarify some points before i send SC for repair.
    summery of where i am in respect to this tv.
    1) SC board is faulty plan on sending to Moduslink for exchange/repair
    2)wanted to ensure that SD and SU boards are not faulty , I am going to check that none of the pins on the ribbon cable are shorted to ground, but I wanted to ensure that I am talking about correct pins/ribbon cable.
    these are the cables that connect SD/SU boards to SC board correct ?? Currently I have Sc board removed and ribbon cable between SU and SD disconnected, I see pins on connector SD 46 (pins 3,5,7) are shorted to chassis ground(screw fastening board to chassis), rest of pins are at 30 Meg or so
    Faulty SD board as well as SC ??
    thanks
    The only pins that we need to check were highlighted yellow in the previous photos, there are some which are also gnd.
    SU41
    All are in respect to - Vfg(floating gnd, the metal plate the bolt goes through)
    pin 2, or TPSU15 (VFO) 2.2Meg
    pin 4, TPSU16 (VSCN-F (TPSC1)) 221K
    pin 8, TPSU17 (5V_F) 5.7Meg
    SD42
    pin 1, or TPSD29 (VFO) 2.2Meg
    pin 2, TPSD28 (VSCN-F (TPSC1)) 221K
    pin 6, TPSD26 (5V_F) 5.7meg
    https://www.badcaps.net/forum/showthread.php?t=46003
    Post #8 has some docs, download G20 series and go to slide 44.
    so long as the above are not short or greatly different(lower) I would assume they are ok. traditionally Vfo will go short.
    here's a spreadsheet I did on 3 board sets. 1 good, 2 x bad
    • Andre Gilbert
      by Andre Gilbert
      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
      11-20-2024, 08:52 PM
    • Biruslapio
      Panasonic P58V11B 8 and 12 blinks error "fix"
      by Biruslapio
      Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
      Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
      04-13-2021, 07:13 AM
    • mecha1166
      XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
      by mecha1166
      I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
      07-01-2024, 05:47 PM
    • jm1234
      Panasonic plasma TX-P42ST50 - 6 blinks
      by jm1234
      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
      I checked that board for any obvious faults...
      05-22-2024, 06:59 AM
    • Alicat
      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
      by Alicat
      Stopped by this site trying to fix my parents Panasonic Plasma TV.
      Model number is TH-50PZ85U
      Power comes on and the red power light stays on solid.
      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
      I also hear a few clicks.
      I also think my parents said there was a thunderstorm and the TV failed after that.
      Section 6 in the service manual talks about power and no screen,...
      10-30-2024, 10:09 AM
