help bricked bios thinkpad t450s
  • leodrago
    • Apr 2021
    • 4
    • italia
    Hi guys
    i traied to remove screen whitelist from bios following a reddit guide but i bricked the bios.
    I reflashed the original dump but the notebook gives me black screen...
    I have also tried this one with the same result: https://www.badcaps.net/forum/showthread.php?t=72997
  • mayss
    • Nov 2016
    • 30
    • Polska
    Re: help bricked bios thinkpad t450s
    If your bios file is original and before modifying this laptop, please upload my cleared bios file and the laptop must start properly.
    • leodrago
      • Apr 2021
      • 4
      • italia
      I disconnected all the batteries, flashed your file, reconnected batteries and charger, turned on the PC and for a moment the keyboard lit up (as with my original file) but then black screen
      • makaveli_763
        • Nov 2020
        • 3
        • England
        Im having the same exact issue as him but your bin file worked but its got password. Do you know what the password is Thanks
        • makaveli_763
          • Nov 2020
          • 3
          • England
          I had the same exact issue also i had forgotten my supervisor password so to completely wipe your bios and make it new with no supervisor password attached to it.
          Follow These Steps
          First apply the Bios patch step 1 and make sure batteries are disconnected.
          Wait for it to boot up then press f1 to go into the bios Password is (1234)
          For hardware id press anything then press enter and space twice it will tell you to turn it off.
          Flash step 2 once its done power it up without connecting the batteries and see if it boots up to the bios screen. It will take about 20 seconds for the screen to show then go straight into the bios set it up how you like and boom you've now got a fresh bios with no passwords attached to it to.
          • mayss
            • Nov 2016
            • 30
            • Polska
            I only cleaned the me-region mapping. Password supervisor should know makaveli_763 because it is his original bios file. I can see that the bios is working and you have patched it. Then the makaveli_763 laptop has another problem not related to the bios.
              • 21916
              maybe he left the unsupported wifi card in .
              • makaveli_763
                • Nov 2020
                • 3
                • England
                Did you know flashing a new bios won't remove the supervisor password since its related to the tpm chip rather than the bios chip. So even if you were to flash a new bios there would still be a password on it
                Also my bios had no other problems as the only problem i had was forgetting my supervisor password which i had set back when i brought this laptop (2015)
                To remove the password you have to use the flashed bios i used which resets your tpm chip completely, Then you would have to flash your orginal bios back.
                My M.2 2242 ssd works also 4g modem and my wifi card so i dont think there is anything wrong with my bios
                • leodrago
                  • Apr 2021
                  • 4
                  • italia
                  I tried makaveli_763's Step 1 with the same result, I have stock wifi card but a custom display... do you think it could be the problem? The custom display worked before I screwed up but I can put stock one back
                  • to5it0
                    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                    by to5it0
                    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                    I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                    This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                    I have opened the laptop and identified the main BIOS chip...
                    10-24-2025, 01:35 AM
                  • lucaszmn
                    Summary of BIOS Whitelist Removal Problem Lenovo Thinkpad T560
                    by lucaszmn
                    Problem:
                    I am attempting to remove the WWAN card whitelist from my Lenovo ThinkPad T560.
                    Initial Findings:
                    • My current BIOS version is N1KET58W (1.45).
                    • I have a CH341A programmer and have successfully created two full backups of my BIOS.
                    • I have the ability to use command-line tools on a Linux machine.
                    Troubleshooting Steps & Conclusions:
                    • I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
                    • I concluded that the
                    08-12-2025, 03:01 PM
                  • akwky
                    by akwky
                    Hi!
                    04-14-2025, 01:56 PM
                  • studdy05
                    Bricked HP Probook 450 G7 Bios questions
                    by studdy05
                    Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                    Ive got...
                    07-08-2025, 09:24 PM
                  • MaxonDomkrat
                    Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                    by MaxonDomkrat
                    Hi everyone.
                    I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                    07-30-2025, 01:27 PM
