Toshiba C650 Not charging and not working with charger on
  • k_shake
    • Apr 2014
    • 5
    • Portugal
    Hi , I have the following problem ...
    Toshiba C650
    MB: 6050A2368301-MB-A02 REV.1
    I have a Toshiba C650 not charging and not working with charger on , this is already the second I get the same problem , the other decided replacing the mosfet Q6002.
    I replaced because I get 19v to the Drain and I get varied between 3V ~ 5V to the Gate, changed and solved problem.
    In this case,I get 19v to the Drain and I get varied between 0V ~ 2V to the Gate, but this time the Source only get 4V~8V.
    In R6036 is supposed to get 19V but only shows 0V ~ 2V,
    in Q6004 is supposed to get 19V but only shows 0V ~ 2V,
    in R6005 one side get 19V at the other side oscillate between 4V~8V.
    In Q6000 get Source 0V Gate 0,08V Drain 4V~8V,
    in Q6001 get source 4V~8V gate 4V~8V drain 4V~8V.
    In D6005 1,2,3, get 19V
    in D6000 2 get 1,55V and 1,3 get 4V~8V.
    Replaced Q6002,Q6005,R6005 and the result was the same.
    I'm suspicious that measuring the U6000 has the following ...
    PIN 1 = 0 ~ 2V
    PIN 2 = 0 ~ 2V
    PIN 3 = 0.07 V
    PIN 4 = 0V
    PIN 5 = 0V
    PIN 6 = 0.6V
    PIN 7 = 4 ~ 8V
    PIN 8 = 4 ~ 8V
    PIN 9 = 4 ~ 8V
    PIN 10 = 0.3 V
    PIN 11 = 4 ~ 8V
    PIN 12 = 4 ~ 8V
    PIN 13 = 4 ~ 8V
    PIN 14 = 0 ~ 2V
    PIN 15 = 4 ~ 8V
    PIN 16 = 4 ~ 8V
    PIN 17 = 0V
    PIN 18 = 0V
    PIN 19 = 1.5V
    PIN 20 = 0V
    PIN 21 = 0V
    PIN 22 = 0V
    PIN 23 = 0V
    PIN 24 = 4 ~ 8V
    Any sugestion? sorry for the bad English I used google translate.
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: Toshiba C650 Not charging and not working with charger on
    With pin 3 that low, R6016 must be open. And there must have been a reason for it happening.
    • k_shake
      • Apr 2014
      • 5
      • Portugal
      Yes the R6016 its open, I replaced 2 times and open again...
      maybe the U6000 is short?
      • atsio
        • Oct 2013
        • 819
        • Greece
        Replace U6000
        • rievax_60
          • May 2012
          • 897
          • australia
          It is possible C6023 might be shorted.
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            i have exact problem with that MB, i replace U6000 (i think it is MAX-im IC) I think i have one left
            ...the quieter you become the more you are able to hear...
            • k_shake
              • Apr 2014
              • 5
              • Portugal
              I Replaced U6000 and problem is solved.
              Thanks, rtstorm,atsio.
              And special thanks for, rievax_60
              • Andyd1970
                • Feb 2013
                • 374
                • united kingdom
                Hi Guys,
                I have a similar model machine a Toshiba Satellite C650-1CT that is totally dead no lights on the front etc.. I have posted a new post someone said it could be Bios but I just stumbled across your post and wonder if I could have a similar issue?
                The motherboard in mine is a 6050A2355301-MB-AO3
                My new post is titled : TOSHIBA SATELLITE C650-1CT Dead!!
                Would be great if you can help me please.
                Thank you
                • rievax_60
                  • May 2012
                  • 897
                  • australia
                  Originally posted by Andyd1970
                  Hi Guys,
                  Thank you
                  Take a look at the schematic in the first post. Power the laptop from the AC adapter only and test the +VBAT voltage. If its 0V, check for +VBAT short to ground.
                  • dj_ricoh
                    • 2073
                    • uk
                    Hi Guys,
                    Thank you
                    My friend i have a big stock of those IC only for this notebook.
                    the problem is U6000 change it.
                    you need to do QFN soldering with hot air and iron for finish on pins.
                    good luck!
                    • Nasir Raja
                      • Mar 2014
                      • 21
                      • United Kingdom
                      Hi guys does anyone have bios for this board. share please??
                        Toshiba Satellite C650-101 C650-15C C650-126 6050A2368301-MB-A02 Laptop Schematic
                        MANAUS 10MD2 MAS10MD2...
                        11-01-2024, 03:13 AM
                        09-06-2024, 05:27 AM
                      • zioricci
                        Toshiba Satellite P855 charger disabled after a while
                        by zioricci
                        Hi everyone,
                        after a little operating time of my Toshiba laptop, ranging from about 20 to 45 minutes, the Power light goes off, the power supply switches from the charger to the battery and in fact the voltage of both gates of the 2 initial mosfets are at 0V so the 19V does not reach the PL201 inductor and the power comes only from the battery.
                        However, when i close the cover to turn off the laptop, the charger starts working again, charges the battery and the Power light turns on in amber color but after about 20 minutes the charger is disabled and the power light...
                        05-05-2023, 02:34 PM
                        Toshiba Satellite L635-10K Notebook Specification for Upgrade or Repair
                        This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                        09-06-2024, 05:59 AM
