Lenovo P52 not powering up
  • Clarify4082
    • Oct 2022
    • 67
    Hi @all,
    I´m stuck in the repair process for a Lenovo P52, Model: 20M9001MGE.
    What was the problem:
    The problem was a boot loop, it started all over again and again.
    Unfortunately the internal display is missing, so I plugged a external monitor, but there was no output.
    I´ve then dissasembled everything and flashed the bios chip with a clean bios. https://www.badcaps.net/forum/showth...&highlight=P52.
    What´s the problem now
    The charging light lights up, when I connect the power cable and have the battery pluged in.
    The power button-LED lights 3 times, when I connect the power cable.
    But when I press the power button, nothing happens.
    When I´ve only insert the battery, there is just a very weak light on the power button-LED for a second, when I press it. There is no fan spinning or other signs of life.
    What I´ve tried already
    Reseated the RAM and try with a known good one. Power drain everything multiple times.
    Flashed a few other BIOS-Versions I´ve found.
    I think it´s not a BIOS problem anymore, there must be something wrong with the hardware.
    I need help to get a starting point where I should look. I´ve already watched a ton of videos, and checked a few things with the multimeter, but no problem described in the videos applies to this board.
    Update 1: Checked the voltage after the DC-Input, 20 Volts are present at the Power fuse 1 and at the current resistor, marked "R005".
    Update 2: Checked the 3,3 rail, and think it´s okay, but I´m not sure, can anybody please check with the schematics (see attachement)?
    Readings:
    PJ11 = 0V
    PJ12 = 5,19V
    PJ15 = 1,85V
    PJ16 = 0V
    PJ17 = 0V
    PJ18 = 0V
    PJ19 = 20,6V
    PJ20 = 5,2V
    Could someone give me a little help and point me in the right direction?
    thanks in advance
    https://www.badcaps.net/forum/showthread.php?t=106150
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Lenovo P52 not powering up
    Check the voltage of PU201 pin 3 / 13 / 12 / 6/ 20 /7 Be careful not to short the pins & the voltage on PL5/ PL4 coils?
    • Clarify4082
      • Oct 2022
      • 67
      Pl4 = 5,2v
      pl5 = 3,39v
      pu201/3 = 3,32v
      pu201/13 = 5,2v
      pu201/12 = 20,6v
      pu201/6 = 3,32v
      pu201/20 = 3,32v
      pu201/7 = 3,31v
      • Clarify4082
        • Oct 2022
        • 67
        Work with correct bios-flash, see: https://www.badcaps.net/forum/showth...&highlight=P52.
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
          Lenovo 3000 Series Schematic
          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
          3000 C100 laptop with Braille keyboard
          Lenovo 3000 C
          C100, C200 - 15-inch XGA screen
          Lenovo 3000 N
          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
          N500 - 15.4 inch screen.
          Lenovo 3000 V
          V100, V200 - 12.1-inch WXGA models
          Lenovo 3000 G
          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
          10-04-2024, 06:05 AM
          Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
          This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
          09-06-2024, 06:40 AM
          This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
          09-06-2024, 06:06 AM
        • bialag
          Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
          by bialag
          I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
          Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
          03-25-2025, 05:56 PM
