HP elitebook 850 G6 bios chip
  • baselse
    • Jul 2020
    • 11
    • Netherlands
    Hi, I am trying to remove the bios admin password of a HP elitebook 850 G6.
    I have a pomona clip for programming the bios.
    Is this the right bios chip? see red circle in the photo.
  • lapfix
    • Mar 2020
    • 2765
    • my workshop
    Re: HP elitebook 850 G6 bios chip
    yes
    • baselse
      • Jul 2020
      • 11
      • Netherlands
      Thanks.
      It is a winbond 25Q256JVEN
      Which programmer would you recommend with this?
      • baselse
        • Jul 2020
        • 11
        • Netherlands
        Thinking about buying this programmer:
        https://www.reveltronics.com/en/prod...programmer-usb
        In the support list is mentions W25Q256JV
        Would it also support the Winbond 25Q256JVEN which is on my Elitebook 850 G6?
          • 21968
          Its a good programmer. The TL866II is a good choice too,with cheaper adapters. Check if your bios chip is SOP8 (with legs) or WSON8 (no legs) .If its WSON8 you may need to desolder it,and use a WSON8 adapter, or buy a WSON8 pogo pin clip.
          • baselse
            • Jul 2020
            • 11
            • Netherlands
            It has legs, so it must be SOP8.
            Thanks, I will look for a TL866II then.
            • baselse
              • Jul 2020
              • 11
              • Netherlands
              I managed to read the bios chip with my raspberry pi and flashrom.
              To be sure the reading was ok, I read the chip 3 times, all files were the same and the size was 32 MB.
              Then I used HP Unlocker to remove the password and I wrote the file to the bios chip.
              So far so good, the laptop boots.
              When I use esc to enter the bios during startup, I no longer get the screen where the administrator password is asked, and it even lets me boot from usb etc.
              But in the bios menu, when I choose the menu "enter bios setup", I get asked for the administrator password again.
              Are there multiple administrator passwords set?
              How to remove all of them?
              I attached the original bios as well as the file which HP Unlocker created.
              Could somebody help me out?
              • skinfus
                • Nov 2022
                • 3
                • France
                I also want to unlock the bios on my HP 850 G6. Which file did you use to remove bios password with HP unlocker? Could you send me the file and software?
                It's my first time doing that so I need some help =)
                • lapfix
                  • Mar 2020
                  • 2765
                  • my workshop
                  Hello
                  For software you have 2 :
                  https://www.badcaps.net/forum/showth...ght=hpunlocker
                  Just dump your file , drag and drop to RCunlocker or hpunlocker file and you got your unlocked file
                  • skinfus
                    • Nov 2022
                    • 3
                    • France
                    Great! Thanks =)
                    I'll try as soon as I receive my CH341A reader.
                    It seems there's 2 bios chips on the 850G6, one 32MB (the one on your picture) and an other one of 16Mb at the back.
                    To fully remove the password it seems you need to unlock the 16mb chip
                    • skinfus
                      • Nov 2022
                      • 3
                      • France
                      Originally posted by lapfix
                      Hello
                      Could you also tell me which software you've used to read the chip? I got asprogrammer but my MX25L25673GZ41 does not appear in the list.
                      • adamgouadma
                        • Jul 2017
                        • 202
                        • setif
                        a HP elitebook 850 G6. 25L128B
                        • niggi
                          • May 2016
                          • 208
                          • UAE
                          yes
                          please remove bios password
                          SN# 5CG0104XWJ
                            • 21968
                            SN# 5CG0104XWJ
                            Read post #10 .Have you tried RCUnlocker ?
                            https://www.badcaps.net/forum/showthread.php?t=103526
                            • niggi
                              • May 2016
                              • 208
                              • UAE
                              Originally posted by smdflea
                              read post #10 .have you tried rcunlocker ?
                              yes but still locked
                                • 21968
                                On the 16MB chip ?
                                • niggi
                                  • May 2016
                                  • 208
                                  • UAE
                                  Originally posted by SMDFlea
                                  On the 16MB chip ?
                                  BOTH CHIPS I'll try but its locked
                                  • nolimit
                                    • Oct 2020
                                    • 4
                                    • germany
                                    can someone help me, to clear PW on Main Bios, because i cant read the 16mB File
                                  • DynaxSC
                                    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                    by DynaxSC
                                    Hi
                                    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                    08-04-2025, 12:20 PM
                                    Common SPI bios chip programming Questions and Answers
                                    by SMDFlea
                                    Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                                    A: If you can`t read from it how do you expect to write to it ?.
                                    Q: Why is my bios chip unreadable ?.
                                    A: The programmer is faulty or has a worn or broken zif socket.
                                    The USB cable is frayed,connector pins worn or some other physical damage.
                                    Not enough amperage or voltage to power the programmer properly.
                                    Bad...
                                    09-02-2021, 04:40 PM
                                  • JoWed
                                    Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                                    by JoWed
                                    Hello Community,
                                    I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                                    07-01-2025, 09:32 AM
                                  • Azurain
                                    Elitebook 840 G5 Bios Chip Soldering Question
                                    by Azurain
                                    Hi everyone,
                                    I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
                                    Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
                                    04-14-2023, 06:58 PM
                                  • BMCappelletti
                                    Asus Chromebox CN62 - wrong chip put on BIOS reader
                                    by BMCappelletti
                                    Long story short:
                                    - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                    - gave the computer to his son a couple years later
                                    - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                    - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                    (seems like the story was not that short)
                                    He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                    01-08-2025, 07:27 PM
