problem with hp 8470
  • marcelofct
    • May 2019
    • 122
    • chile
    hello friends i have a problem with this laptop and it does nothing i need your help
    I have made these measurements:
    19v in fuse
    3 volts in power button
    in u6100 charger (TPS51123RGER) I have:
    VIN: 18.35V
    EN0: 3.11V
    REG5: 4.96V
    REG3: 3.25V
    ENC: 0.06V
    please help me
    attach schematic
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: problem with hp 8470
    Check U6104 and Q7350 as you dont have EN_5V_3V(ENC). Btw, U6100 is not charging IC, its your 3V/5V Regulator IC.
    • marcelofct
      • May 2019
      • 122
      • chile
      I followed what you told me and
      U6104 has voltage on pin 1 (3.2v) and on pin 2 I have no voltage, I only have 3.3v on pin 5, I think that on pin 1 is the KBC_PWR_ON signal
      the other signal is CPPWR_EN that goes to pin 2 and I do not have it, I followed it and I do not have it in the kbc, thanks for your help I stay tuned
      • marcelofct
        • May 2019
        • 122
        • chile
        someone help me
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • hazim
          HP 8470 battery problem
          by hazim
          I have a problem in hp 8470
          Laptop work normal with charger only with out battery
          When I shut down and remove charger and but the battery ( work with battery only ) laptop works on an external monitor only (black laptop screen) keyboard and touchpad completely stopped
          When I shut down and remove battery and work with charger only laptop work normal
          If I work with charger and battery together (black screen ) keyboard and touch stopped
          Chang ram, change more than 2 new batt
          I need your help Thanks a lot
          08-19-2023, 10:05 AM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
        • Gibon378
          Problem with stopping audio and video for no reason
          by Gibon378
          PC Specs:
          • CPU: Ryzen 5 1600
          • GPU: GTX 1080 Palit JetStream
          • MOBO: ASRock ab350 PRO4
          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
          • PSU: XFX 650W (don't remember what model)
          • OS SSD: ADATA SP920
          • OS: Windows 10 21H2
          Problem description:
          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
          11-19-2022, 09:41 AM
        • perzyk23
          Lenovo T580 - LCD Panel problem - error 0288
          by perzyk23
          Good morning,
          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
          10-25-2024, 12:42 AM
