Toshiba 32AV504D clicking then switches off
  • shaunbt123
    • Nov 2012
    • 119
    • uk
    hi everyone.
    ca someone please give me some advice regarding the fault with my tv.
    when you press the power button on front panel the green led lights up then the relay on powerboard clicks after 5 seconds the green led goes out and just the red led remains on.i have checked the electrolytic caps all seem ok with good esr readings.i have tried it without inverter board plugged in but the problem is the same.
    thanks in advance.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Toshiba 32AV504D clicking then switches off
    Hi have you checked out that white block resistor and whatever is under it?
    There must be another board where the black and white leads from the top of the board go.
    Perhaps check the voltages on the connectors to the main board
    a) when its just plugged in
    b) when you press the power button
    c) when it goes into fault.
    Another thing to try is to unplug the cable that goes from the main board to the panel
    it is just to the right of the Genesis chip.
    I am seeing a lot of sets on here where the main chip on the main board is damaged by a power surge on the HDMI on this one it looks like there is nothing at all to offer protection so guess hdmi should only be plugged when the set is off/unplugged to be safe.
    • shaunbt123
      • Nov 2012
      • 119
      • uk
      thanks for your help,those black and white wires go to the inverter board,im going to try and unplug the lvds cable from the side of the chip now and report back with what happens.ill get those voltages for you tommorow.
      thanks again.
      • shaunbt123
        • Nov 2012
        • 119
        • uk
        i have tried unplugging the lvds cable but the problem is still there.
        • shaunbt123
          • Nov 2012
          • 119
          • uk
          i have taken some voltage readings from top connector of power board
          these are with the cable unplugged from main av board.
          5v-------------5.16v
          3.3v-----------0v
          6v-------------0v
          9v-------------0v
          i then reconnected the cable to av board and tested again.
          switch on power button on front of tv and get these voltages
          5v--------------5.07v --------relay clicks then drops to 0v
          5v--------------5,07v---------relay clicks then drops to 0v
          3.3v------------3.4v-----------relay clicks then drops to 0v
          6v---------------6.07v---------relay clicks then drops to 0v
          9v---------------8.9v-----------relay clicks then drops to 0v
          really hope someone can help .
          thank you.
          • wolfnick
            • Oct 2013
            • 3
            • romania
            I have exactly the same problem? Has anyone found the cause? Has anyone solved this defect?
              09-06-2024, 05:27 AM
              09-06-2024, 05:59 AM
              Toshiba Satellite L635-10K Notebook Specification for Upgrade or Repair
              This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
              Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
              This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
              09-06-2024, 05:33 AM
