Crown LED 32185 no power no standby
  • ragis
    • Mar 2013
    • 51
    • Bulgaria
    Hi, folks i have a problem with this TV it has no power or standby led on
    PSU - 17IPS11-R4
    MB - 17MB82-2
    I've done some measurements:
    D107 - OK - 0.230R - 28V
    D120 - OK - 0.560R - 28V
    D136 - OK - 0.560R - 28V
    D124 - OK - 0.560R - 28V
    D126 - OK - 0.560R - 28V
    The 4 D120-D126 are connected parallel
    The main cap C101 - 68uF/400v shows 330V DC
    Q105 - FDPF7N60NZ - OK
    D130 - MBR10150FCT - OK
    C113 - 100uF/100V - 28V (Someone before me had replaced it)
    I've measured the voltage from CN100 and attached it but where the +5VSTBY must be there are 0.21V
    I appreciate your help, best regards
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Crown LED 32185 no power no standby
    Your Psu is ok, these literally only have a 12v and 24v output (24v goes straight to Led driver) they use Dc-Dc converters on the motherboards for the 5vstby and other rails on these.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Your motherboard likely has corrupt firmware which is not turning on the standby Led, have you checked to see if the Ir sensor has its 3.3v and 5v on it ? Thats one way to check if the motherboard is at fault. If it does your motherboard is bad.
      • ragis
        • Mar 2013
        • 51
        • Bulgaria
        Thanks for the reply, now i checked CN18 on the MB and it has 5V on the pins, then checked the LED and it has 3.3-3.5V.
        So i think it gets his voltage, now what can i do or the MB is dead ?
        Checked the LED and IR pcb - they both get 5V and the LED is ok it's not burned.But it can't just turn on or show standby maybe it's the MB what can i do to fix it or just have to replace it ?
        Thank you again, best regards
        • ragis
          • Mar 2013
          • 51
          • Bulgaria
          Ok, the MB is dead officially...
          I freezed the EEPROMs and no power/stnby...
          Let it RIP
          I think i'm gonna try with new MB.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Yeah go for it but be sure to match your motherboard to that exact panel if not it wont work
            • ragis
              • Mar 2013
              • 51
              • Bulgaria
              Ok, thanks can you tell me exactly what to look for the MB serial is:
              17mb82-2 1912012
              I've found some near around me i've upload it in the attachement
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                What panel does it use ? VES315WNDS = VESTEL 31.5" Led Module With Samsung Display. Will be something like that.
                • ragis
                  • Mar 2013
                  • 51
                  • Bulgaria
                  The panel is VES315WNDS - 01
                  Below the barcode there is another:
                  VEL_LCM VES315WNDS01_IPS11_32185_MB95
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Yeah thats a Samsung Lsc320ap01 Lcd screen. Just look up the model of your Tv into ebay and see if any boards come up matching that screen.
                    • ragis
                      • Mar 2013
                      • 51
                      • Bulgaria
                      No matching, my TV is not listed in ebay...
                      If i order the same part number of the mb from another tv will it work or no ?
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        You need the board to work with the exact same screen and Psu if not it wont work.
                        • ragis
                          • Mar 2013
                          • 51
                          • Bulgaria
                          ok will this match:
                          MAIN AV BOARD 17MB82-2 19122012 23133239/23134654 NEO LED-32165DL PANEL VES315WNDA-01_TW IC TAS5721
                          MT5820LUNU
                          MT5135AE
                          TUNER
                          LC-32LD145K 32" LED TV 17MB82-2 19122012
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            No thats not a match, thats for a Ves315WUDA = Auo Lcd glass. Your Tv does not have that screen. You need a board that uses VES315-WNDS nothing else ! If not it wont work.
                            • ragis
                              • Mar 2013
                              • 51
                              • Bulgaria
                              Ok, thanks mate for the help i've found similar board from:
                              Panel:VES315WNDS-01
                              MB: 17MB95M
                              PSU: 17IPS11 (300413-R4) which is like mine but has +cap C112 but i can add it to my PSU
                              One think i'm concerned about the backlight one friend told me to test it with the multimeter in diode mode on the 5th pin of the CN14 but the backlight didn't start... Do you have any idea or i have to tear down the panel i think if the backlight is off i can trow this damn TV in the junkyard
                              I've attached the similar mb and psu and the test for the backlight
                              Thanks again, i really appreciate your help sir
                              • tvguy12012012120
                                by tvguy12012012120
                                02-07-2025, 05:13 PM
                              • fharris1977
                                Vizio D50u-D1 Dead Set No Standby
                                by fharris1977
                                Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                12-28-2023, 10:25 AM
                              • Crystaleyes
                                Samsung BN44-00259A standby question
                                by Crystaleyes
                                Hi all.
                                I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                08-11-2023, 05:15 AM
                              • psssst
                                Yamaha TSX 120 Standby Problem
                                by psssst
                                Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                03-01-2024, 07:25 AM
                              • ChristianBr01
                                LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                by ChristianBr01
                                I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                04-23-2025, 01:48 AM
