Hi, I've got a HP EliteBook 8760w with no CPU VCore, L6, L7, L8 all have no Vcore voltage. VCCSA is present. What should I check next? thanks
HP EliteBook 8760w - No CPU VCore
Re: HP EliteBook 8760w - No CPU VCore
Check enable signal on U1010 pin 7.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Originally posted by Francisco.s View PostThen check PWR_GOOD_3. Pin 4 U1012 should be 3 volts.
pin 1 is 3.3V
pin 2 is 1.4mV
pin 3 is 0.0mV
pin 4 is 0.0mV
pin 5 is 3.3VLast edited by Johndill; 06-21-2018, 05:36 AM.
Apparently PGOOD_MXM is needed for PWR_GOOD_3 to go high and get the CPU power regulator to turn on. PGOOD_MXM comes from the MXM connector apparently, and has a pull-up resistor to +V3S.
Is there a graphics card plugged in in the MXM connector? If there is, remove it, it may be pulling down the line (for an unknown reason right now).OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Originally posted by piernov View PostApparently PGOOD_MXM is needed for PWR_GOOD_3 to go high and get the CPU power regulator to turn on. PGOOD_MXM comes from the MXM connector apparently, and has a pull-up resistor to +V3S.
With MXM GPU removed, L6, L7 and L8 are open line, hot CPU, PWR_GOOD_3 pin 4 U1012 is 3.3 volts.Last edited by Johndill; 07-12-2018, 02:26 AM.
Is the computer booting without the MXM graphics card? Try to see if there is any HDD activity, any sound coming out from the speakers, if caps lock/num lock trigger the associated LED.
This MXM graphics card seems to be pulling down the PWRGD line so try with another graphics card if you have one.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Originally posted by piernov View PostIs the computer booting without the MXM graphics card? Try to see if there is any HDD activity, any sound coming out from the speakers, if caps lock/num lock trigger the associated LED.
The caps lock stays solid lit without the GPU connected so would it be right to say the motherboard is fine and the issue would be with the GPU?
I have a GTX 675M in my Alienware but don't really want to take it out :-)
Check if you can turn off/on the caps lock light. Put an hard drive with an operating system and check if it's being read. (you should hear the heads moving at least)
You'd have to try with another graphics card to make sure it is indeed the issue.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Originally posted by piernov View PostCheck if you can turn off/on the caps lock light. Put an hard drive with an operating system and check if it's being read. (you should hear the heads moving at least)
The caps lock was solid lit and did not turn off when pressed.
I'll clean it out and reassemble it for easier testing of your suggestions and replay back some time soon when I have completed your tests and maybe bear it and try out the GTX 675M from my Alienware as it's the only working MXM card I have and unfortunately HP didn't enable the intel integrated GPU on this board.Last edited by Johndill; 07-13-2018, 06:58 AM.
You'd have to try with another graphics card to make sure it is indeed the issue.Last edited by Johndill; 07-13-2018, 09:24 AM.
Great!
Could you take pictures of the dead MXM card?OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
MXM graphics cards has 3 different versions which are probably not compatible. In addition, if you buy a MXM card, it can not be trusted. Thus, finding and buying a compatible MXM card takes time.
to test the old card, first check whether the tantalum capacitors or the coils are shorted or not. but probably, the gpu chip should be failed.Last edited by caspian; 07-13-2018, 12:23 PM.
Its MXM3.0b . http://forum.notebookreview.com/thre...581056/page-72
Originally posted by SMDFlea View PostIts MXM3.0b . http://forum.notebookreview.com/thre...581056/page-72
