View Single Post
Old 09-30-2010, 01:55 PM   #61
PlainBill
PlainBill's Avatar
City & State: Phoenix, AZ
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
Default Re: Sony Bravia no picture but backlight on
Quote:
Originally Posted by BCR View Post
The cable is good, it is a 1 meter cable that I use everyday on the PS3 straight to other TV, but I did try a second cable to be sure. As well, went around every board on TV and checked connections, all look good (some grease, but that is standard).
It doesn't have to be a connector. Lead free solder is notorious for prodicing joints that look good, but are intermittent. When you plugged in the cable you put pressure on the circuit board, causing it to flex slightly. That caused two points to rub across one another and make contact - at least for a while.
The explanation is easy. Finding the bad solder joint is the hard part. The good news is the harder it is to find, the greater your sense of accomplishment when you succeed.
PlainBill
__________________
PlainBill is offline   Reply With Quote
