Windbond 25R256JV VS. W25R256JVEIQ
  • zeppis
    • Feb 2021
    • 10
    Hi, I recently damaged a Bios chip 25R256JVEN, I cannot find the same model number and letters, Is there any difference between the chips that ebay sells and this one? Thank you for your knowledge.
  • gaxxter
    • May 2020
    • 5
    • uk
    Re: Windbond 25R256JV VS. W25R256JVEIQ
    look at data sheet!
    • BSamvelov
      Bios that supports Title letters in password on disk
      by BSamvelov
      Hi everyone. I used Acer Travelmate 6292 with BIOS v.13112, Santa Rosa 1436 (VGA Bios version). This BIOS supported title letters for creating password on HDD.
      A week ago an element on textolite burnt and I cant turn on laptop.
      I thought that title letters support different types of BIOS.
      I tried my new laptop lenovo and my friends old Acer and to regret nor mine nor his laptop doesnt support title letters in
      Standart HDD 2,5 inches.
      How can this problem be resolved?
      Lots of BIOS versions of different types of laptops support title letters in password?...
      05-18-2024, 03:51 AM
    • JohnNovak
      Samsung CRT TV letters or text is shadowing
      by JohnNovak
      Hi.
      I have some problem with old CRT TV Samsung model: CW-29Z338T, 29" size TV.
      The problem is that letters and other text are not clear, text or letters are shadowed on the right side.
      I found 2 capacitors on CRT Picture Tube Board.
      47uF/400V was leaking very bad, the second cap 10uF/250V was bad ESR reading so i replace this cap also.
      Replacement these 2 capacitors did not help nothing.
      I try to reduce brightness, contrast and sharpness. There is very small effect on this shadow.
      To reduce G2 down have more effect...
      11-21-2024, 09:52 AM
    • Andri15
      Asus x450ep keyboard doesn't work some letters
      by Andri15
      hello friends, I hope someone can help me with the case of the Asus x450ep rev 2.0 mobo, the problem is that there are some letters that don't work, I've tried replacing it with another keyboard, but still the same letters don't work, I'm confused about where have to measure it....
      09-04-2024, 06:12 AM
    • Xristakis795
      le40b530w colour problem and double letters
      by Xristakis795
      hi to all on the above model i have solarized picture and double letters
      it uses tcon board FHD60C4LV1.1
      i think as about as the double letters maby the problem is the same display
      but as about as the colours it likes as solarized picture
      i look to find the schematic for the above tcon card without success
      has anybody measure the voltages from the above tcon card to advice me how can i measure the gamma voltages ?
      thanks on advance
      07-10-2023, 02:31 PM
    • CapThatBrass
      RT809F Chip Write Failure - Winbond 25R256JV
      by CapThatBrass
      I've managed to take an image dump in BIN format of my Dell Latitude 5420, which had a Winbond 25R256JV chip installed.
      I used an RT809F programmer to obtain the BIN, using the supplied iFix RT809F programmer application (latest version being 20220830).
      The programmer automatically found the settings to read the chip but selected the Winbond W25Q256FV instead (my actual model isn't available on the listing within the software). The image came out fine - I did this multiple times to clarify the data being read was the same each time.
      10-04-2022, 11:56 AM
