My new tower fleet
  • seanc
    • Nov 2008
    • 1319
    #41
    Re: My new tower fleet
    How can you be so sure that was the issue?
    Have you identified the failed part? We're just hypothesizing (I think).
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      well... the cpu is not detected. the memory is another issue.
      besides, i stripped it for caps for the abit. what a PITA to recap. it still isn't done, i really am leaning towards finding another here or on ebay.
      sigpic
      (Insert witty quote here)
      • seanc
        • Nov 2008
        • 1319
        #43
        Are you having problems cleaning holes or getting caps out?
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          its more of making what i have fit. i don't have one of the types (16v 470uf)... ill check a couple more dud boards...
          besides, the board is almost too big for the case i'm using... it bareley fits...
          if it works, ill find my t-bred 2400+ for it. i also have 4gb ddr for it.
          sigpic
          • 370forlife
            Large Marge
            • Aug 2008
            • 3113
            The gutter guard looks ok, but the hot glue dosen't. I would peel it all off, make the gutter guard about 1/4" bigger than the opening on either side and hot glue it in there, or use something more permanent.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              i did. the reason the glue is also on the outside becase i tried to use it as bondo and trying to use the dremel to blend in the edge of the plastic created an uneven edge.
              also, i was afraid the glue would de-bond on the saddle cover. it already is starting to come off.
              if i thought i could pull it off, i might dremel the hot glue so it blends in (shape-wise). then, i might spray paint it.
              sigpic
                • 31316
                if you have to do this type of thing, then use epoxy resin.
                you can sand it afterwards like a car body repair - then spray the whole panel with acrylic paint.
                as for hot-crap,
                i refuse to call it glue.
                put the plastic in a fridge or freezer for a while or spray it with freezer.
                then it will break clean off.
                that stuff is useless if it gets cold.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  works fine for me. epoxy isn' the cheapest....i might redo it down the road, but il try sanding the hot glue first.
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    good news. i looked in my dead mobo pile, and found the caps i need:
                    1 1000uf 6.3v (sanyo or nichicon HE, the HE's have very little use on them)
                    4 470uf 16v (Nichicon vr, found on a dead ell board)
                    1 25v 100uf (nichicon)
                    ill put them in tomorrow... we'll see if it works.
                    sigpic
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      i killed the abit. i split 2 traces that were not fixable.
                      damn it... and i have nothing...just damn it.
                      sigpic
                      • seanc
                        • Nov 2008
                        • 1319
                        #51
                        So, go back to finding the bad component on the previous dead board and we'll see what we can do with it.
                        You can run your server off one of your older PCs - what's it doing, file sharing?
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          it would be run off my gaming tower...
                          and, as i already said, the msi is DEAD!!! there is no point in beating a dead horse...
                          sigpic
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            i bought a new board for the mini-server. when it comes in, ill have pics.
                            sigpic
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              i got the board...
                              the chipset fan was dead. i replaced it.
                              it will not boot. it posts, but when it is supposed to boot, it locks up. changing drives has no effect on it. i tried a different psu, no effect. i tried playing wirh memory, nothing. i tried a couple agp cards. no luck. i have not tried switching processors, as that is a pain.
                              ideas?
                              sigpic
                              • seanc
                                • Nov 2008
                                • 1319
                                #55
                                Tried a different PSU?
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  i said so! i did!
                                  sigpic
                                  • seanc
                                    • Nov 2008
                                    • 1319
                                    #57
                                    Yep, I glossed over that bit, sorry.
                                    What is this board?
                                    What caps does it have?
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      it is an asus a7v133 1.05.
                                      all caps but 2 are rubycon of fujitsu poly. 2 are nichicon (idk the series, could be hm, could be vr or he or the like)
                                      sigpic
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        solved.
                                        i swapped form an 1800+ palomino to a 1ghz t-bird. it likes the t-bird; the 1800+ is fried.
                                        damn it!
                                        sigpic
                                        • Scenic
                                          o.O
                                          • Sep 2007
                                          • 2642
                                          according to the asus website you need at least BIOS version 1007 and PCB version 1.05 for Palomino Athlon XP's
                                          http://support.asus.com/cpusupport/c...Language=en-us
                                            HP Z240 Tower Workstation i5-6500 Specification for Upgrade or Repair
                                            This specification for the HP Z240 Tower Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z240 Tower Workstation boardview and Z240 Tower Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-12-2024, 03:44 PM
                                            HP 240 Tower E3-1245V5 Specification for Upgrade or Repair
                                            This specification for the HP 240 Tower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 240 Tower boardview and 240 Tower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP 240 Tower is accurate,...
                                            HP 240 Tower i7-6700 Specification for Upgrade or Repair
                                            HP Z240 Tower Workstation E3-1245V5 Specification for Upgrade or Repair
                                            HP Z240 Tower Workstation i5-7600 Specification for Upgrade or Repair
