Compaq question
  • stevo1210
    • Oct 2006
    • 4156
    Compaq question
    I need to fix a laptop for my friend this Friday. She says it's been working very slow and stuff... she hasn't had it reformatted since the day she bought it a few years back. It's a Compaq laptop and runs on Windows XP... That's about all I know right now.
    Now I have heard that Compaq uses recovery CDs or something? and not the average joe Windows CD like Dell does?
    So what CDs/DVDs exactly does she need to hand over to me so I can reinstall Windows back to the original factory configuration?
    Then there's the driver issue which I will have to sort out afterwards *sigh*.
    Thanks.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • stevo1210
    • Oct 2006
    • 4156
    Re: Compaq question
    Also, would it be a wise idea to run memtest before ahnd to check that everything is in order?
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      Re: Compaq question
      Stevo I did a nice Hp Compaq Lappy for my son sometime back and here is what I can tell you. Off the top I think it was a d 530 maybe. I do remember that it had almost every option you could think of. I used OTC windows xp corp sp1 on it. I then installed sp2 and sp3 off of my cd's. I then downloaded all of my drivers from the Hp Compaq site free of charge. The hardest one was the last device that windows just called and "Unknown Device. I think the thing was a TCM. Anyway I installed the TCM device drivers and all was good. Be sure to make a list as you download these drivers as the files only have a number, and no name. Give yourself plenty of time to do this thing. I don't think its a one nighter the first time around. I have all the drivers burnt to disk for Allen's and I still don't think I'd sit here and do it all in one evening. Oh and the blue tooth gave me a pain to because I didn't know it had it until I loaded a driver for it. Take your time and you will "Git-R-Done!"
      "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
      Mark Twain
      "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
      John Paul Jones
      There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
      Rod Serling
      • NxB
        • Feb 2009
        • 1595
        Re: Compaq question
        It will work with whatever windows license she has on there. If its pro you need pro retail. It could also be home or possibly media center.
        • Player2
          • Aug 2009
          • 98
          Re: Compaq question
          The computer may have a recovery partition on the hard drive, from which you can burn recovery discs or do the whole recovery from the computer.
          • Junk Parts
            Court Jester
            • Jun 2006
            • 8953
            Re: Compaq question
            Good point Player2. I did one that was like that. Had to hit one of the F keys on the boot to go into the recovery mode. Don't remember what F key it was that I hit. If he would put the model # on the post I'd find out for him.
            Mark Twain
            John Paul Jones
            Rod Serling
            • Junk Parts
              Court Jester
              • Jun 2006
              • 8953
              Re: Compaq question
              Ok this is what I got from my brother. To get the compaq restore to run here is what you do. This will only kick in and do anything if there is a restore partition on the disk. On the boot repeatedly tap F1, F2, F10 or delete. One of these keys should get you into the compaq restore. I would say that you would tap this thing about the same time as you would if you were trying to get into the BIOS screen. If you get a keyboard failure warning it just means that you tapped too soon in the boot up. If there is no compaq restore you can always use the microsoft Xp restore which is F8. Do this in the same way....
              Mark Twain
              John Paul Jones
              Rod Serling
              • stevo1210
                • Oct 2006
                • 4156
                Re: Compaq question
                I have the laptop here now... it's a Compaq Presario V2417AP with an AMD Sempron 3000+ CPU, 256MB RAM and a 40GB HDD.... that's pretty okay for todays standards I suppose. It comes with Windows XP Home Install CDs and a driver CD so I'm all set to do a Windows reinstall.
                • stevo1210
                  • Oct 2006
                  • 4156
                  Re: Compaq question
                  Just an update... I finished the job on Sunday night but didn't deliver the laptop back to my friend until the Tuesday. She seems pretty happy with it so I suppose I've done everything correctly. The hardest part was backing up all her files and emails because some files were corrupted, but apart from that everything else was easy as pie.
                  • Wizard
                    • Mar 2008
                    • 2296
                    Re: Compaq question
                    That one is mobile sempron. It's okay but it is even slower than even a P4. Make sure the cooling is GOOD since the thermal management is really sloppy with AMD-based notebooks and they overheat, die due to half-baked investment in quality AMD notebooks due to putting these notebooks in the lowest price point scale back then. This what was the case with 2 AMD based notebooks, and crappy chipset with *tiny* heatsink perched on the ALi north bridge like too small hat on one's head. Both DEAD as nail. :P
                    Cheers, Wizard
                    • stevo1210
                      • Oct 2006
                      • 4156
                      Re: Compaq question
                      Oh shit. The CPU fan looked pretty dusty when I had a look at it the other day and I tried my best to vacuum it from the outside with no success. Anyway should I issue a recall for this laptop?
                      • Wizard
                        • Mar 2008
                        • 2296
                        Re: Compaq question
                        Yes, very important. This is reason for data corruption as well.
                        Cheers, Wizard
                          HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                          This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                          09-12-2024, 03:44 PM
                          HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                          This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                          This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                          09-12-2024, 03:36 PM
                          HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                          This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                          09-12-2024, 03:30 PM
                          HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                          This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
