Replacement fan cables
  • Jooo
    • Oct 2011
    • 222
    • Finland
    So, basically I have some fans that have been used in other projects and have their 3pin connectors ripped out.
    Now me being a cheapskate and not wanting to throw them away because "they could be useful".
    I started looking ebay if I could find new 3pin cables / wires for them but could not really find what I was looking for, the wires were either very short or just expensive.
    This was the best I could find: https://www.ebay.com/itm/10pcs-PC-Fa...e/281523816728
    but even that seems fairly expensive for what it is, and i would have to cut the male conn out anyway to be able to solder the wires directly to the fan.
    I was thinking that maybe I have the wrong keywords and if anyone could help me find the cables that I am looking for, I could imagine that someone here has dealed with the same problem before (fan connectors cut off due to fan being used in other project).
    Basically only need 3pin female to a wire ended cable, probs something like 50-60cm lenght would be ideal.
    The fans are cheap fans anyway so it's really not even worth the labor, but just thought it would be something to do on the spare time.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Replacement fan cables
    it would equal less than $1 per fan. While they're apart, clean & grease the bearings/bushings and they'll be like new. I restore fans all the time and repurpose them. If I rob a fan from a PSU, I'll solder new wires with 3-pin plugs on them, it takes all of 30 seconds....it takes longer for the iron to heat up.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      • 31144
      you can get the cables on aliexpress
      • Jooo
        • Oct 2011
        • 222
        • Finland
        Found some, here they are in case someone else is looking for them: https://www.ebay.com/itm/KF2510-Conn...e/223591864225
        • Bezel018
          • May 2019
          • Poland
          This is good try.
          • emil_t
            RTX3090 working fine but fans not spinning
            by emil_t
            Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
            04-12-2024, 06:54 AM
          • b-slayer
            Asus Strix-G15-G513RM fans don't work
            by b-slayer
            I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
            The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
            (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
            (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
            ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
            09-04-2025, 04:58 AM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • the_rem
            Unknown transformer : how to find a good replacement part ?
            by the_rem
            Hello guys,
            I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
            I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
            04-23-2025, 01:48 AM
          • ezenia
            PS4 controller left stick potentiometer replacement issue
            by ezenia
            Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
            So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
            I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
            09-30-2023, 02:19 PM
