Optiarc
+ More Options
Posts
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Optiarc
    i have them still. i will try that.
    sigpic
    (Insert witty quote here)
    • Bushcat
      Pioneer PL-X9 motor speed control wobble
      by Bushcat
      I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
      Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
      BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
      05-24-2023, 03:36 AM
    • EduCabral
      [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
      by EduCabral
      I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
      While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
      🔧 Details:
      • Model: YT-M06
      • Interface: Pioneer 1
      • MCU: Fujitsu MB89F202
      • Goal: Find a valid .bin firmware file or memory dump from a working unit
      I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
      Yesterday, 12:26 AM
    • pixelcap
      Pioneer Kuro Pro 111FD 8 red blink error
      by pixelcap
      Pioneer Kuro Pro 111FD 8 blink red LED.
      I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
      So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
      based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
      10-06-2024, 11:26 PM
    • RatherLoopy
      Pioneer VSX-44 receiver HDMI dropouts
      by RatherLoopy
      I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
      I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
      And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
      05-26-2023, 03:54 PM
    • Evets
      Pioneer sg530
      by Evets
      This forum has been so useful to me and I thank all the people who have helped me in the past.
      I'm now in need of some more assistance, I have purchased a Pioneer sg530 graphic equaliser to add to my Pioneer X-G7 hifi system. This equaliser was a factory option on this system but as this was purchased second hand I didn't get a user manual. Searching the internet has been fruitless, can anyone help with a schematic of how this should be wired into the system or possible a copy of the user manual.
      07-30-2024, 07:18 AM
