Yay, new fans!
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Yay, new fans!
    Ordered up some new fans for my computer, 3x 92mm Nidec va350dc's. 92mmx38mm, 110cfm, 5100rpm, 51db. I chose these because even though you can get a delta 160cfm for 3 or 4 dollars, they are whiners like these nidecs, but so much louder. These new fans are replacing the front, rear, and cpu fans.
    Also a chance to check on and clean out the Tpower and its 100% ucc caps, thanks biostar!
    In the first pic you can see the 240cfm nidec ta600dc I have on my side panel
    I set up the new fans so that the front and rear fan would blow in, doing two things:
    1. pressurizing the case (this became apparent upon first start up with new fans, dust blew out of all the cracks and crevices), also allowing the ta600dc to be able to utilize all 240cfm's by actually having some air to work with and not pulling a huge vacuum.
    2. the rear fan would blow cool air for the cpu and psu to pull through.
    Here you can see the new fans in all their glory. They are brand new, never used before fans. Made in japan, nice. Not as nice as the ta600dc on the side, thats American made .
    Hmmm, no wonder that old front fan was not pushing as much air as I remember it doing. Only a foot thick layer of dust on it. Twas only $2 on newegg, they are what are in the back and front, from masscool, oem to fannertech.
    Well, now the front and rear is in place, time to do the cpu which is going to be a challenge because they use this plastic clip that spreads apart after you push it through the hole. I am also going to mount the fan pulling through the cooler, which means I will need something to cover the gaps between it and the 'sink. I can tell you that the fan is a Y.S. tech 92mm capable of about 48cfm, and is a PWM fan.
    Now I just need to take a picture of the finished project and maybe one of the finished noise
    Ohh ya, and no bla bla bla about doing it on the carpet, as that was only for taking pictures, it was done on my usual solder station in the basement.
  • Phaihn
    • Jan 2009
    • 842
    Re: Yay, new fans!
    Sweet fans.
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
    • pentium
      • Mar 2006
      • 2778
      Re: Yay, new fans!
      That fan on the side is sure brilliance.
      Find Nedry!
      Check the Vending machines!!
      <----Computer says I need more beer.
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        Re: Yay, new fans!
        Now I got to decide where to put the other one
        2 for $10 was a deal I couldn't pass up.
        Heres the rest of the pics
        When I first fired it up I found the front fan was only pulling about as much air through as the original fan did. I thought it was defective at first, but it was being choked trying to pull the air through the little holes.
        Did a little more cable management
        • Wizard
          • Mar 2008
          • 2296
          Re: Yay, new fans!
          Did u run them quiet at low voltage? These particular fans are LOUD at rated voltage.
          Cheers, Wizard
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            Re: Yay, new fans!
            He he he he, no.
            Currently I just un-hook the molex connector for them if I want them to be quiet.
            • emil_t
              RTX3090 working fine but fans not spinning
              by emil_t
              Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
              04-12-2024, 06:54 AM
            • b-slayer
              Asus Strix-G15-G513RM fans don't work
              by b-slayer
              I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
              The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
              (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
              (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
              ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
              09-04-2025, 04:58 AM
            • JayPoorJay
              Hot Water Rad - A Few ECU Fans and a Timer Switch
              by JayPoorJay
              Good Afternoon, Good People.
              I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
              I REALLY would appreciate y'alls help.
              This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
              10-29-2024, 12:54 PM
            • sda sad
              my Xiaomi Notebook Pro X laptop fans work like crazy for no reason
              by sda sad
              Hope this is the right place, someone can help me.
              My laptop started having a really strange problem....
              When I turn it on the fans start working at a crazy rate and with random breaks...
              They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
              And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
              The model of the computer:
              Xiaomi Notebook Pro X 15 OLED (A30)
              04-23-2024, 09:55 AM
            • joesmoe91
              Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
              by joesmoe91
              My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
              02-22-2024, 07:38 PM
