Topcat's Dream Service Bench Reborn!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Topcat's Dream Service Bench Reborn!
    Just a bump to let anyone that gives a hoot I'm still plugging away at this....
    I used to tease old geezer techs that used these.....but I won't anymore, as my aging eyes have come to appreciate it these days! It's a Luxo circa 1960's, all metal with a glass lens. They're around, but most of the knotheads on ebay think they're worth $100 + ridiculous shipping....I found this at a local junk shop for $19. Base was missing, but it was easy to fabricate. Anyone can get the cheap plastic ones......but I'll pass.
    If anyone remembers the CM2220 from earlier....well I found a CM2250 on ebay for $10, not working.....
    I figured I'd take my broken CM2220 and this one and make one working unit.... Well, the fix for this one was simple....so I've still got a broken but intact CM2220. This one came with all the adapters, cables, and the colorometer as well....I'll have to tinker with that feature.
    The other CM2220 that I found along the way. Even today, I find these quite useful. Great for dialing in & burning in older analog stuff, and even useful for modern stuff.
    THis is the next to go, big tool box full of mechanics tools.....I've been making a spot for it out in the garage..... I'll fill in the space it consumes with something else I'm pondering...
    That's all for now......
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      • Jul 2011
      • 6067
      TopCat
      You are a very busy person do you have time for anything
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        TopCat
        Sometimes I wish I had a "mini me"...or two.....but I'm not easily entertained, so I don't watch TV or sit around and do nothing....I always find constructive things to do....albeit some might argue what I consider to be 'constructive'....
        ....but for what it's worth....
        Center island roll-around table. I built 2 of these tables 15 years ago (cut a 4x8 sheet of 3/4" plywood in half to make the tops, the rest is pretty self explanatory). I've used it in this room on occasion as needed, but most the time it was used in the garage. I modified the outer edges with some 1x6 I cut down to create a 'track' to lay carpet in, so I can use it in this room.....but if I need it out in the garage for something gunky, the carpet will lift right out....but at this time, its going to be more useful in this room.
        ...and the toolbox moved out to the garage... I have an idea of what will occupy this space....I just have to build it.
        Team : 49813
        Join in!!
        Team Stats
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          Originally posted by Topcat
          .....and its probes & leads are still hiding somewhere.
          I was in the attic looking for something completely unrelated....when lo&behold the pair of original Sencore sc3100 probes turned up!! woohoo!
          Team : 49813
          Join in!!
          Team Stats
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            Boring slow Monday....so I figured I'd play around with my vectorscope. I never had a complete understanding of how this thing worked, it came in a lot I bought from a defunct TV shop back in the 90's..... Shortly after I got it, an 'old world' TV tech walked me through using it, but that's long gone from my brain. He said it was more for setting up IF's and video signals on old analog TV & video equipment with manual adjustments, where more modern stuff is set by IC's/processors (not adjustable). He demonstrated on an old projection screen TV, fascinating to watch him, but I never completely grasped what he was doing. ...What the hell, lets see if I can make it do anything....
            The basic setup was a junk DVD player someone gave me, o-scope, vectorscope, and a TV to monitor the output.
            Trying to remember what he told me over 25 years ago, using a non-static signal (something that changes such as CATV, MATV, or in this case a DVD), its pretty meaningless. However when using a static signal from a generator (not shown in my pics but I did do), that's what you use to dial things in...explaining the correlations of what's showing on both scopes and what's showing on the screen....and you would adjust the IF's accordingly....of course this is moot on modern stuff....but what could be more fun on a cold/boring Monday.
            Team : 49813
            Join in!!
            Team Stats
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              A $5 flea market score, nice addition to the front bench....if nothing else, its good for quick checks of PSU's and CMOS batteries.... It is a Heathkit IS-1202 with a nixie tube display. It was made in 1972.
              In good physical condition and after being cleaned & serviced.
              After replacing a fuse and 2 bad lytics, its working fine....but was way out of calibration...DC was reading a good +4v off on any range, AC would drift (I blamed the bad caps for that, recapping it seems to have fixed that), and the meter wouldn't zero out, it would sit +0.7v on any voltage type or range. Finding the procedure was a searching feat, but I found it...
              Back in tune!!
              The 200 range...
              Calibrated!
              Nifty piece for 5 bucks!
              Team : 49813
              Join in!!
              Team Stats
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                Another Nixie tube wonder, $20 ebay score..... It's a Hickok DMS 3200 Mainframe. I was confused about this until it got here, I only bought it because anything that lights up and has Nixie tubes in it is worth $20... This was made to accept 'modules' for different types of uses that would display on the nixie tube display. The module that happen to come with it was a capacitor tester (ironic?)... After researching, there is a DC volt module, resistance module, frequency counter, event timer....and probably others that I haven't seen. Finding these modules will probably be nothing short of a miracle.....but I'll certainly keep my eyes peeled.
                Anyway....powered up, and zeroes out.
                Testing using a 150uF cap....
                Verifying with my LC102:
                Now an 820uF cap.....lucky me, 777!!
                Sencore verified...ok, that range is a little off. I'll have to see if I can find a calibration procedure for this....this machine has got to be 50+ years old (research says it's circa 1966).
                Mainframe cover off:
                ID plate:
                Now for the module....I wanted to see what was in it....
                Reassembled.
                The female part....
                All back together:
                This is more of a display piece than really having a practical use on my main bench.....but fun to tinker with all the same and maybe find additional modules for it....
                Team : 49813
                Join in!!
                Team Stats
                  LCD LED TV Service Menu Codes
                  ALL LCD LED TV SERVICE MENU CODES
                  Service Menu Code with Board Name
                  China Universal Board / Jumper Board Service Menu Code
                  Changhong Ruba Service Menu Code
                  Ecostar LED TV Service Menu Code
                  Orient LED TV Service Menu Code
                  Haier LED TV Service Menu Code
                  TCL LED TV Service Menu Code
                  Samsung LED TV Service Menu Code
                  LG LED TV Service Menu Code
                  Videocon LED TV Service Menu Code
                  Supra LED TV Service Menu Code
                  Toshiba LED TV Service Menu Code
                  Symphony LED TV Service Menu Code
                  Veste/ LED TV Service Menu Code...
                  10-31-2024, 03:58 AM
                • AustinCER
                  Dell XPS 8940 | Manufacturing Mode? | No Service Tag
                  by AustinCER
                  Hello, I currently have a Dell XPS 8940 in our office for repair.
                  Service Tag: HG1Y673
                  The most recent BIOS is pictured below -- being available as an .exe on Dell website.
                  Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
                  Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...
                  07-15-2025, 05:28 PM
                  Acer Aspire A517-52-326E + Extended Service Plans Notebook 5 Specification for Upgrade or Repair
                  This specification for the Acer Aspire A517-52-326E + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A517-52-326E + Extended Service Plans boardview and A517-52-326E + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                  09-07-2024, 02:20 AM
                  Acer Aspire A317-33-P9DS + Extended Service Plans Notebook 3 Specification for Upgrade or Repair
                  This specification for the Acer Aspire A317-33-P9DS + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-33-P9DS + Extended Service Plans boardview and A317-33-P9DS + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                  Acer Aspire A317-53-32Z4 + Extended Service Plans Notebook 3 Specification for Upgrade or Repair
                  This specification for the Acer Aspire A317-53-32Z4 + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-53-32Z4 + Extended Service Plans boardview and A317-53-32Z4 + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
