HDDs shutting down at 2/3 of the surface when writing on them?
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: HDDs shutting down at 2/3 of the surface when writing on them?
    Originally posted by Behemot
    Guess you must have ACCIDENTALLY missed posts #10 and #12.
    It's unclear what you are claiming in #12. What exactly did you do? Which drive (the original? or "the small WD"?) Are you now claiming a 250GB 2.5" drive is ALSO failing at "2/3" (which is now a completely different LBA number)?
    Do you really think different drives (and sizes) all have a problem at 2/3 offset?
    You've obviously ruled out the common aspect in each of these cases: the PC!? (and whatever software you are using)
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8327
      Seagate 3TB HDD's have a high failure rate anyway. I'd stay away from these.
      • Curious.George
        • Nov 2011
        • 2305
        • Unknown
        OP is apparently claiming that 250GB WD drive has similar problems. I'd hold off on tossing a 3T drive until I was pretty sure the problem wasn't pebcak or related!
        • Behemot
          • 4845
          • CZ
          Yeah, guess what, I am claiming multiple different drives from different series of different manufacturers seem to suffer from this problem:
          …Basically especially large-size drives (2+ TB, but also seen that for 250GB 2.5" drive too)…
          Maybe, just maybe, you know, like…do your reading…again?
          Some of the drives were tested hooked to two or three different controllers each under different OS. I think that obviously if I have not ruled such thing already and I was not seeing that for wayyyy different drives, I would not be asking here about such stuff, right? C'mon, dude! I am no frelling beginner in this, think better of me will ya
          Plus I have no idea where that talk about platters not spinning came from. I clearly stated the drives SHUT DOWN. They go dead. Disappear from device manager. Until power cycled again. Maybe you'll understand it said in this way better?
          It has nothing in common with any overheating, it depends always no matter what the internal or external temperature is. One of the affected drives is 2TB WD Green, cut down to some 1200 gigs, I've already put gazillion of TV series on it, runs 24/7 for several weeks now just fine. That's while working ONLY on the first 1200GBs, not further.
          There's simply SOMETHING screwed up between the platters/heads-electronics-firmware. Since WD claims there is no new FW for at least this particular drive, guess we can rule FW out, at least the general part, maybe drive-specific (service) data are bad, but nobody here sees inside this thing I guess. The problem also appears to develope over time, and does NOT happen anywhere else on the surface, so I expect it is not connected with the heads rather then the particular SECTORS, aka SURFACE.
          That happening to multiple drives from WD or Seagate makes mi kinda wonder WHAT the heck exactly is bad inside them that it results in same same behavior, instead the usual reallocation of sectors when it does behave strange when you try to WRITE over it.
          • Curious.George
            • Nov 2011
            • 2305
            • Unknown
            Maybe, just maybe, you know, like... PROVIDE REAL DATA IN YOUR REPORTS!
            I don't think it is too hard to say:
            "Make/Model drive failed when running program XXX reporting OK until sector YYY was accessed, then went offline. Attempts to talk to drive controller resulted in ____. Device not seen as verified by _____. Experiment repeated (after cooldown -- or not!) with results that were identical/different in the following ways... Then tried the same experiment with another make/model that showed similar problems: x, y and Z. And, yet another COMPARABLE drive that showed NO problems (to help rule out a problem in your setup)"
            Think better of US and provide hard data that you can see but are too lazy to report to us, in detail.
            My disk wiper logs the DETAILS of every failure so I don't risk folks discarding drives only to discover there is a problem in the test rig, software or test procedure. I'll trust my own wetware to see if there is any pattern in the "failed" drives before pronouncing them "defective". I won't expect an operator/user to have those sorts of observation skills!
            I ran a batch of 22 assorted drives through it last week and found two that were clearly defective. But, also noted that another was performing at such an abysmal rate that it is either destined for failure or is simply too crappy to justify keeping. I know that only because the software takes lots of notes throughout the process (retries, remaps, data rate, etc.) to notice aberrant behaviors -- things that a casual (likely unmotivated) observer wouldn't notice!
            • Sparkey55
              • Jan 2010
              • 1523
              Originally posted by curious.george
              maybe, just maybe, you know, like... Provide real data in your reports!
              "make/model drive failed when running program xxx reporting ok until sector yyy was accessed, then went offline. Attempts to talk to drive controller resulted in ____. Device not seen as verified by _____. Experiment repeated (after cooldown -- or not!) with results that were identical/different in the following ways... Then tried the same experiment with another make/model that showed similar problems: X, y and z. And, yet another comparable drive that showed no problems (to help rule out a problem in your setup)"
              think better of us and provide hard data that you can see but are too lazy to report to us, in detail.
              My disk wiper logs the details of every failure so i don't risk folks discarding drives only to discover there is a problem in the test rig, software or test procedure. I'll trust my own wetware to see if there is any pattern in the "failed" drives before pronouncing them "defective". I won't expect an operator/user to have those sorts of observation skills!
              +10,000
              • Behemot
                • 4845
                • CZ
                #27
                Kinda difficult when they already are (s)crapped mr. clever! Besides, I really see no reason to differentiate brands and models when clearly DIFFERENT drives from different series and even generations are affected, and yet too many of them to consider that coincidence are affected.
                Besides, keeping about 2 TB from 3TB drives is way too much of candy (and movies and other pr0n) to let go just like that…
                • Curious.George
                  • Nov 2011
                  • 2305
                  • Unknown
                  #28
                  For example, I've had nothing but bad luck with WD Green drives. So much so that the three 2TB Greens that I pulled from this latest server will go straight to the scrapper WITHOUT being tested (why waste 3 hours on each drive only to discover problems??)
                  And, if every drive was failing at sector XXXX, then I'd look hard at driver and MB related issues. Saying "2/3" doesn't mean sh*t. Is it ACTUALLY 2/3? Or, 35/52? Maybe 95/141?? Or, is that just the limit of your arithmetic skills? I'd wager that it wasn't "2/3" and that the fraction you experienced on the 250G drive was different than on the 3TB drive -- yet you only offer up one figure: "2/3".
                  I sure hope no one ever asks you to design a bridge or anything where details actually MATTER! (I suspect you're a "board swapper"... as that limits you to just a few diagnostic choices when faced with any technical problem: it's either board A, B or C!)
                  • Behemot
                    • 4845
                    • CZ
                    #29
                    I think you should talk about it to some specialist. Just take it easy, all right?
                    • Behemot
                      • 4845
                      • CZ
                      #30
                      So far I got success with the 250gig 2,5" drive, bypassing the damaged space there is 140GB usable partition good for data and 50GB partition good even for OS for some ages old, slow and cheap system (like this HP 530, for example).
                      The 2TB green seems to also work this way, currently in the process of formatting 655GB partition, next to already working 1200GB partition…so I'll pretty much use almost the whole capacity, not bad
                      • captainKKK
                        • Sep 2018
                        • 287
                        LOL pebcak, I learned some new 20 something slang to use on my customers....
                        Hey Curious.George, mind sharing the name of your testing SW for hard drives? After reading this forum I am gonna have to say, have you tried formatting these offending hard drives ON A DIFFERENT COMPATIBLE HOST?
