Mozilla "status-4-evar" add-on gone?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16955
    WTF?!
    https://addons.mozilla.org/en-US/fir...status-4-evar/
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • petehall347
    • Jan 2015
    • 4422
    Re: Mozilla "status-4-evar" add-on gone?
    https://addons.mozilla.org/en-US/firefox/
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16955
      Not sure what your point was with that.... "No results were found for "status4evar"."
      Team : 49813
      Join in!!
      Team Stats
      • retiredcaps
        • Apr 2010
        • 9271
        Source code at
        https://github.com/SparkyBluefang/S4E
        --- begin sig file ---
        --- end sig file ---
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16955
          Originally posted by retiredcaps
          I;m a coding idiot....I'd have no idea what to do with that, I actually did find that when trying to research this. I'd like to track down the .xpi files for various elderly versions of firefox. I'll have to see if the .xpi's are in the user data directories on various systems where it's installed.
          Team : 49813
          Join in!!
          Team Stats
          • hasefroch
            • Apr 2013
            • 42
            • Argentina
            The good old Archive.org to the rescue:
            http://web.archive.org/web/201206082...4.21.13-fx.xpi
            If you know the original url of the extension, most probably the Archive has copies of it. YMMV
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16955
              That worked for that version....but I needed some other versions, along with some other things that Mozilla apparently discontinued support for. I managed to find them all.
              Win2k, XP, and other older MS OS's:
              C:\Documents and Settings\someusername\Application Data\Mozilla\Firefox\Profiles\blah.default\extensions
              Win Vista, 7, 8, and all newer:
              C:\Users\someusername\AppData\Roaming\Mozilla\Firefox\Profiles\blahblah.default\extensions
              Some are named for what they are (s4e was), some aren't...but all end in .xpi. Copy them to your archive and name them whatever (I named them by version), and just do the manual install process through the add-on manager...and you're good to go. If you're not sure what it is, try to install it...it will tell you, then just cancel the install and rename the file accordingly.
              Team : 49813
              Join in!!
              Team Stats
                HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                09-12-2024, 02:00 PM
              • Dannyx
                How I "fixed" the display on an Akai LT-3220AD TV
                by Dannyx
                Good day folks. I thought I'd share with you something I did today, just for a laugh and for a bit of a discussion, since I'm still not entirely convinced what happened there.
                I found an Akai LT-3220AD TV in the dumpster - literally - so me and my colleague brought it back into the shop and dusted it off a bit to see if someone maybe gave up too soon.
                Long story short: backlight came on but had no picture. My colleague attempted to reprogram the SPI chip but it didn't change anything, so we concluded it must be the panel that's faulty, especially after reading about it...
                01-29-2024, 10:12 AM
              • leszekp
                KLMAG1ETD- TP point
                by leszekp
                Hi , I am looking TP point for KLMAG1ETD in MT58CU chassis TCL .I have not seen it in UFI pictures .
                02-13-2025, 05:41 AM
              • DynaxSC
                Each GPU reballing produces different MATS results, looking for root cause ?
                by DynaxSC
                I have an Nvidia card which makes me wondering, what is the root cause for Mats errors. The story is as follows:
                1. When I received the card Mats showed one memory with errors.
                2. Replaced the memory chip, but no change, still same error, so memory chip is ruled out.
                3. Made a carefull reballing of the GPU, MATS showed 3 memories with errors, the one before, and 2 other new chips.
                4. Made a second reballing of the GPU and Mats shows again only one memory chip with errors, the same on as in the beginning.
                5. Made...
                12-11-2024, 07:44 PM
              • Norrecito
                iPod nano G3 - alternative soldering point for the white battery wire
                by Norrecito
                A friend of mine gave me an iPod nano G3 to see if I can fix it for him.
                The device had a faulty battery and he tried to replace it but failed. In the process he managed to pull off the pads that corresponds to the white battery wire (marked with a red circle in the images)....from both sides of the PCB. Fortunetely he didn't damage anything else.
                This is usually an easy fix HOWEVER, on the PCB, I see no traces coming from the VIA and after searching the internet, I've found no schematics nor boardview for this device. With the pads gone from both sides I seem...
                09-07-2024, 03:54 AM
