Capacitor question
  • Tygur
    • May 2009
    Capacitor question
    I am replacing a number of caps in my monitor. 2 of the caps i originally wanted to order were on backorder until august, so I was given a "better" cap, going from 25v to 50v. What I didn't realize is that the diameter looks pretty much doubled and I'm not able to seat them completely and they also touch each other. Will I be ok if I use them like this until I can get the proper size caps, or do I need to wait until I get them before installing anything?
  • NxB
    • Feb 2009
    • 1595
    Re: Capacitor question
    25v to 50v might not be the way to go. Depends where the caps are in the circuit. I'd say find another source of caps and get the right ones.
    If the contacts make it through the holes and the legs don't touch anything metal you are OK. Then again you have 2 reasons not to use these caps.
      by momaka
      03-12-2025, 03:42 PM
    • clearchris
      New capacitor technology - high lifetime caps
      by clearchris
      I'm getting ready to put in a capacitor order. I generally look for nichicon, panny, kemet, or united chemicon, and I'm noticing that there aren't any 1000 hour caps anymore, and not many 2000 hour caps. Most of the caps are rated around 5000 hours or better. Last time I ordered, 1000 hour caps were pretty much most of them, and the very few 10,000 hour caps had pretty bad specs.
      So what's the deal, have we made major progress with capacitor reliability in the past few years? Are these high lifetime caps ok to use? It's not that I wouldn't welcome the change, I really would, I'm...
      03-26-2021, 06:39 PM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • Prolog
      by Prolog
      12-01-2024, 08:27 PM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
