Radeon X850 pro...
  • HenryJ
    • Oct 2006
    • 54
    Radeon X850 pro...
    Anyone still using one.
    i sure could use some help on R17 value located fan side above gold finger 8
    Regards: HenryJ
    edit: 4 spelling
  • Toasty
    • Jul 2007
    • 4171
    Re: Radeon X850 pro...
    Hi HenryJ,
    Is the resistor damaged or missing? Or, you don't know how to get the value?
    Can you post a pic of the problem part or area?
    Toast
    veritas odium parit
    • HenryJ
      • Oct 2006
      • 54
      Received this missing along with C81 C82 so no pic or code to crack.
      Thanks for your input !
      • HenryJ
        • Oct 2006
        • 54
        Longtime comming on that pic Toast but with the help of plain Bill i'm able to post pic this time so here you go
        • Toasty
          • Jul 2007
          • 4171
          Without a reference X850 Pro card, there is no way to get that resistor value. If I had to -guess-, I would use the same value as R16 on the back side.
          Same goes for the 3 missing caps C81,82,86. Those caps are decoupling caps to keep noise off the lines. You could take one off the reverse and measure it to get a value.
          That resistor is extremely small. Trying to replace it is going to be very tricky at best as it's 2 x 1mm. The surface tension from the solder alone will drag it off the pads. Those are placed with a solder paste/glue that is cured then heated in a -very- precisely controlled environment to get the solder to flow. Be aware that heating and soldering on one side may cause you to lose components on the other. A too high wattage iron may destroy the traces and pads.
          Plus, you'll need a very good magnifier and a super steady hand. Get extras of each as you're gonna lose one...
          Toast
          veritas odium parit
          • Wizard
            • Mar 2008
            • 2296
            I have done it, need a needle tweezer to hold it down while soldering.
            Philips modules are filled with those microscopic SMD devices.
            Cheers, Wizard
              AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
              The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
              10-01-2024, 12:46 PM
              AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
              The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
              10-01-2024, 01:07 PM
              AMD Radeon RX 470 / RX 580 Schematic & Board View
              The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
              10-01-2024, 12:52 PM
              AMD Radeon R7 340 / R7 430 Schematic & Board View
              The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
              10-01-2024, 12:36 PM
              AMD Radeon RX 7900 XT (RX7900XT) Schematic & Board View
              The Radeon RX 7900 XT is an enthusiast-class graphics card by AMD, launched on November 3rd, 2022. Built on the 5 nm process, and based on the Navi 31 graphics processor, in its Navi 31 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 7900 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 31 graphics processor is a large chip with a die area of 529 mm²...
              10-01-2024, 12:20 PM
