Gigabyte EP45-UD3R pin 25 of parallel port not grounded
  • japlytic
    • Oct 2005
    • 2086
    When I connected a remote control programming cable I made myself, it would not work. I then found that Pin 25 on the parallel port (Pin 24 on the parallel header on the motherboard) was not grounded.
    Grounding Pins 18-25 on the remote control programming cable made it work again.
    Was a special parallel port backplate required?
  • Wizard
    • Mar 2008
    • 2296
    Re: Gigabyte EP45-UD3R pin 25 of parallel port not grounded
    Consult the latest parallel spec and see if said pin is noted what it is was and implment a fix to bring it into complicene standards.
    Cheers, Wizard
    • Harvey
      • Apr 2007
      • 264
      Why would Pin25 on the port connect to Pin24 on the header?
      • japlytic
        • Oct 2005
        • 2086
        Standard parallel connector backplate:
        DB25F connector - parallel port header on motherboard
        1-1
        2-3
        3-5
        4-7
        5-9
        6-11
        7-13
        8-15
        9-17
        10-19
        11-21
        12-23
        13-25
        14-2
        15-4
        16-6
        17-8
        18-10
        19-12
        20-14
        21-16
        22-18
        23-20
        24-22
        25-24
