Have FTA receiver with pvr function supported, that says record/play with a external HDD,my question is there any special HDD that i should get to work with this type of fta receiver?thanks in advance.
Fta Pvr Hdd?
Re: Fta Pvr Hdd?
Usually they use a 2.5" HDD which is usually SATA. But I've seen some which use 2.5" SATA HDDs as well.Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous -
Re: Fta Pvr Hdd?
Oops, I actually meant 2.5" SATA or in some cases 3.5" SATA. I've never seen a PVR use a PATA HDD though but then again I haven't seen many PVRs....Originally posted by zandrax
Do you mean Pata and Sata, don't you?
ZandraxDon't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - AnonymousComment
Re: Fta Pvr Hdd?
Direct Pata or Sata connection for internal drives, since it's both faster than USB and with a lower processor load; being external, I suspect USB 2.0 or (maybe) Firewire.Originally posted by WizardWhat does the PVR box uses? USB? Or direct PATA or SATA?
I think they used Pata until 2006, when 2.5" Sata drives became widely available: the point is PVR of the time were a lot expensive (something like 600+ euro, $800+) so they were sold in small numbers.Originally posted by stevo1210Oops, I actually meant 2.5" SATA or in some cases 3.5" SATA. I've never seen a PVR use a PATA HDD though but then again I haven't seen many PVRs....
BTW, if it's external then it's likely to use USB 2.0 as a connection port.
ZandraxLast edited by zandrax; 03-03-2009, 04:17 PM.Have an happy life.Comment
by DynaxSCHi,
I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
The board is generally working now, all PCIe ports are working, Windows installs normally.
However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA... -
This specification for the HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 3TB SATA 6Gb/s 7200 HDD boardview and Z2 G4 + 3TB SATA 6Gb/s 7200 HDD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-12-2024, 03:28 PM
This specification for the MSI Gaming GE62 6QD-452FR Apache Pro Heroes Special Edition Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GE62 6QD-452FR Apache Pro Heroes Special Edition boardview and GE62 6QD-452FR Apache Pro Heroes Special Edition schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-06-2024, 05:30 AM
by clabrNeed help to solve some problems with this laptop.
After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
Before this had happened I observed some other problems:
When I tried replacing original mecanical HDD with a SSD HDD could not get them... -
by CDNBrewerHello Everyone,
I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
Symptoms:- Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
- Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
- I swapped the Left and Right surround
- Loading...
