Windows 10 Update 1709 Stuck
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    This update didn't have any trouble on my MSI laptop or my Lenovo IdeaPad, but on my ThinkPad T430 I'm having a heck of a time getting "Feature Update to Windows 10, Version 1709" to install. All of the computers were running version 1703 previously.
    Basically when I try to update it, either by clicking "update and restart" button in the start menu power menu, or directly from within Windows Update, it just restarts my computer like normal.
    I have tried running the "Windows Update troubleshooter" and clearing Windows 10 update cache as per this article, because I assumed the download was corrupted (the computer was restarted/shut down many times during the download process for other reasons, and I actually went from HDD to SSD via cloning partway through that process). So it's definitely possible the download was corrupt.
    http://www.intowindows.com/how-to-cl...in-windows-10/
    When I did those steps, it deleted multiple gigs of stuff, so it worked, but Window Update still thinks the update is ready. I can't run Windows Update again to get it to realize it's not because it just says the update is ready to install, and even after restarting several times, the start menu still shows "update and restart" though I suspect the update is now deleted...
    What do I do? Reinstalling OS is not an option I just finished setting everything up on here.
  • dragos2009
    • Mar 2013
    • 110
    Re: Windows 10 Update 1709 Stuck
    just update it using this https://www.microsoft.com/en-us/soft...load/windows10 site to download the update assistant it is way more easy and trouble free than the windows uptade
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Totally forgot about that, thank you. It worked perfectly!
        LCD LED TV Service Menu Codes
        TCL LED TV Service Menu Code
        LG LED TV Service Menu Code
        10-31-2024, 03:58 AM
      • T4-BR
        T470S - TPM issue since TPM/BIOS update from Windows Update
        by T4-BR
        Many thanks for the high quality ressources available on your website.
        I'm currently facing some issues with my T470S:
        - I sat a Supervisor Password using special chars which was causing issues
        - Access to BIOS was locked but I was still able to use my PC
        2 weeks ago, I got an update of BIOS/TPM from Windows Update.
        Computer restarted and after Lenovo logo a loading bar appeared and at the end something went wrong + an error popped.
        Computer restarted one more time and I got the prompt for typing Bitlocker...
        09-26-2024, 02:50 AM
      • reformatt
        Windows 11 Start menu/Taskbar hanging
        by reformatt
        Couple of Windows 11 machines have come in this week with the same issue. After you login, the taskbar will not appear (or just be a black bar). No access to Start Menu. Task Manager (use CTL+SHIFT+ESC) works, however the Performance stats seem stuck with CPU on 100% for Task Manager itself. Trying to exit Task Manager result in it hanging as well. No issue if you boot into Safe Mode.
        First machine, tried many things to no avail (System Restore from last Windows update, rebooting in Diag mode, trying to reinstall Windows Apps via Powershell). In the end, I did an in-place upgrade...
        04-23-2024, 10:16 PM
      • 0xx
        2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
        by 0xx
        Hi folks,
        My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
        What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
        I assumed that Windows Update was interrupted due to closing...
        09-14-2025, 03:46 PM
      • dqtech
        MSI GL63 8RD stuck after windows loading
        by dqtech
        in bios setup this laptop was running ok....but when boot to windows, will stuck like this after windows loading....i've try change another ssd and try to reinstall windows but this problem still persist...ampere also drop from 2amp (at windows loading) to 0.8a (when stuck).....any help?...
        07-07-2023, 06:51 AM
