It's coming. Right now, I'm testing function of the machine; testing the tester!!
The only glitch is the TPU STBY lamp not going out when the TPU powers up. To correct that I would have to add another relay to the mix to deactivate it when TPU power is sensed and trips it from an outside power source. The IPU would do this... but honestly, not really worth the effort, I'd have to add a relay and a few wires. Maybe someday, but its not a problem....just a glitch.
I tested a plethora of various boards so far. Only quirk so far with function was some Foxconn 3rd gen I-series board that for some reason did not like the SATA to IDE adapter....at all! I also have some small SATA DOM's with boot utilities on them as backups for things like this....but no other board has had any issues.
I've also found it's just easier to leave all the ATX & EPS extension cables plugged in. Some boards need the extensions, some don't.....but the constant plugging & unplugging is probably just going to cause wear & failure. The extenders are cheap & plentiful....if I wear one of those out, no biggie. The main harnesses that go through the floor of the case would be a nightmare to have to repair/replace!
The case bottom is actually buttoned up on this. All the transfer switches are connected and working as they should. I'll have more pics later.....but for the first time since this started, the case for the Dolby unit is closed up!!
There are a few revision / finishing touches I want to make before actually installing this in the rack. For example the rear of the test bay, I want to make a blockoff plate where the KB/MS & VGA cables enter. That opening is where an ATX PSU once was. Good location for the cabling, but that needs to be cleaned up.
Glad I could be some inspiration! It's why I share projects like this....if helps one person along the way, it served its purpose.
Be careful experimenting with lithium ion & lithium polymer batteries, they can be a fire hazard!
