Asus P5K-E WIFI BIOS.
  • stevo1210
    • Oct 2006
    • 4156
    I have a problem....
    I recently reflashed the BIOS on my Asus P5K-E WIFI AP motherboard and now the bootup splashscreen says it's a P5K-E, and not a P5K-E WIFI AP like before. Motherboard works fine without a problem though.
    I went into the BIOS and the option to switch off the Wireless card is still there, so I'm not sure if Asus was just lazy and didn't bother writing "WIFI AP" in the splashscreen or if there's something wrong?
    I did however download the correct BIOS from the Asus website, so I know that I'm not wrong. Should I be concerned?
    Thanks.
  • stevo1210
    • Oct 2006
    • 4156
    Re: Asus P5K-E WIFI BIOS.
    I just went to the Asus support website and the BIOS for the P5K-E WIFI and the P5K-E are exactly the same files. Could this explain everything?
    • jpdoe
      • May 2007
      • 237
      No reason to worry. It's not unusual that motherboards in the same family share the same bios file. And as time passes, the manufacturer only updates one of them to save a few bucks.
      • travistee
        • Sep 2008
        • 68
        I have that same mobo.
        Do you know if 2 X 2GB 800 will work ok with XP?
        • stevo1210
          • Oct 2006
          • 4156
          I'm not really sure of that, because I have 2x 1GB sticks. But 2x 2GB should work with XP because the max limit for XP is 4GB, but it will opnly address 3.25GB of that 4GB.
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • mozzwald
            ASUS Prime Z790-P WIFI D9 BIOS Trouble
            by mozzwald
            Failed BIOS flash caused no post/fan spin/flashing power led. I have backed up both chips (8 & 16mb) after failed flash. I extracted BIOS from ASUS site and flashed it to 16MB chip but same problem. It appears the ME version in the backup is very old (16.1.25.1865) and not even listed in the ASUS downloads page so I assume the ME update failed. I tried extracting the ME firmware from new ASUS bin/cap file and flash it to the 8MB chip but same issue. Not sure what to do to recover from this. Any help appreciated.
            10-01-2025, 07:21 PM
