Enough psu to sli?
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Enough psu to sli?
    I am thinking about buying another 9800GT for my computer to sli it. Im just wondering if my psu can handle all of it. Its a 500W rosewill stallion RD-500-2SB. I have a 5000+ dual core, 4 gigs of ddr2 800 (2x2gigs,) 320gig WDC, dvd/cd-rom, Biostar Tpower N750 motherboard, and 2 80mm fans, 1 92, and 1 120mm.
  • bgavin
    • Jan 2007
    • 1355
    Re: Enough psu to sli?
    www.jonnyguru.com
    This guys dissects a lot of power supplies, and isn't very kind to most of them. Yours might be listed there.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      www.hardwaresecrets.com as well
      So I hear Jonnyguru retired and someone else is running the show there now.
      Mann-Made Global Warming.
      - Dr Seuss
      • Fizzycapola
        • Oct 2006
        • 423
        I'd rather have a single card that out performs 2 mediocre cards. Consider an 8800 Ultra (£100) OC2 or Geforce 260 / 280 GTX, swapping up the CPU to something nearly as good as you can get like an E6850 (£60) may give nearly best performance currently purchasable or within a negligable few percent of it*. (* in real world - maybe not some abstract benchmark that has no relation to reality)
        If you're lucky you may find you can sell your graphics card and buy a much better one for nothing. ( i.e public assumptions that GF9 > GF8, despite 8Ultra OC [ just look at it's monsterous bandwidth 100GB+] being virtually on par with GF10)
        I don't know what game you're playing, but my friends extreme budget PC, £250 - E6850 GF8800GTS (G80) been running Crysis mostly smooth (40+FPS) on high detail 1280x1024, if thats any help to you.
        If you're main issue is full HD gaming, perhaps you're right to go SLI though. I see some tests where it helps in that aspect particularly.
        Also not forgetting tweaking your current system and graphics card registry particulars. I have found it can make a huge difference. I managed to get an extra 200FPS whilst also increasing image quality the other day using some of my unique knowledges on graphic card registry tweaks.
        Rubycon Rubycon Rubycon
        • 370forlife
          Large Marge
          • Aug 2008
          • 3113
          I might buy 2 8800GTS's soon, my friend upgraded from those to two gtx260's.
          I believe they are both 1gb Palit cards. IDK, maybe he would trade my 9800GT for those plus like 100 dollars. He was originally going to sell them to me for 200.
          • Fizzycapola
            • Oct 2006
            • 423
            Some important links for you:
            http://service.futuremark.com/hardwa...rdsList.action
            http://www.guru3d.com/category/vga_charts_crysis/
            Notice how using 2 graphics cards instead of one, orindarily only achieves a few more frames per second. Particularly the difference between using 1 GTX to 2 GTX is from 51 FPS (Single card) to 60FPS (two cards in SLI)
            I was going to buy some 1GB Geforce 8's myself, until I learn they come bottom of all tests, even high resolution and texture tests they always came bottom, slower than the 320Mb ones.
            • mutumarian
              Hi, i need boardview for N750-1GD5/OC msi 750 oc 1gb
              by mutumarian
              i have an old gpu and i would like to repair
              10-27-2024, 10:50 AM
            • jorpec
              Need BIOS dump for Biostar TPower X58A
              by jorpec
              After a bios update, the motherboard stop to work, only the Re-live screen appears with instructions how to recover the bios, i have follow the instructions, tried multiple pen-drives but it seems the motherboard can't read them, so i thought about write the chip with a memory dump
              It has a MX25L8005 chip.
              Thanks...
              08-25-2025, 03:40 AM
            • 370forlife
              Rules of sli??
              by 370forlife
              I'm going to get a brand spankin' new PNY pci-e16x 2.0 nvidia 9800GT 512mb video card, so what am i going to do with my old XFX pci-e16x 1.0 8600GT 512mb? My question is can i sli it with my new 9800GT??? My biostar Tpower N750 has a 750a chipset, and 2 pci-e 16x 2.0 slots (8x in sli i believe,) if not i will put it back in my old ECS 3200+ motherboard so i can do some decent gaming on my computer at my dads.
              10-11-2008, 09:25 PM
            • 370forlife
              Problem with delta dps-700fb
              by 370forlife
              Ok, so a problem has sprung up with it. Sometimes, when trying to start my computer, it won't. I will hit the power button and the power light and hd light just stay solid, fan on video card spins up to full speed and stays there, and no post. Resetting usually does no good, I have to hold the power button until it turns off, unplug the psu, hit the power button, replug it in and hit the power button. Then repeat until it finally starts.
              Strange thing is it does it over time. For the first 10 or so start ups it works like a charm, then it will do it once, then start up, then twice...
              12-20-2009, 08:45 AM
