Picked up this deskpro PII 350 (desktop factor form) from local computer store in 2002 that replaced a utterly unreliable MII Cyrix server with my 1999 9GB 7200 that WD obtained from IBM under license.
Ran 98 and this DOS software that is specialized for our needs, other companies do use this as well and they said same thing can't find like that for ease of use and rapid entry without having to mousing around.
For some reason either 98 is not so stable or the generic ram I used in the Deskpro was ever so slightly unstable so I wasn't sure about. Even this, kept going for whole six years with daily power cycle, on at each start of the day, turn off at end of that day in andout for years, and software/hardward maintaince, yearly or so dusting off.
Till recently we started to have hard errors in software (corruptions) so had to pull down this box and put in Pentium Duo 2.2 with intel chipset everything XP, same old software so ever vital, new for not so much cost with success and a PCI-E 2 port parallel adapter by Bytecc for driving 2 dot matrix printers and a USB samsung laser. Works like a treat. No crashes or corruptions.
Now to the old box I dissected the PSU and checked ESR. Only whopping one 100uF needs replacing, only just passing. Rest of caps are good, including the mainboard!
Nichicon and Rubyicons. Even the slot 1 Vcore utilized truly MASSIVE 4700uF 6.3V fat caps in group of seven. Not even a swell.
At one point, replaced CPU for PIII 500 (board supports this). Is there a known issues with PII/PIII deskpro?
Cheers, Wizard
Cheers, Wizard
