Cannot Find Audio Drivers- ECS MCP73PT-PM Motherboard
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    HI all. I am service an old '08 eMachines(I hate their computers w/ a passion) computer that had Micro$haft Winblows $#!+sta on it. It had fouled up, so I put a clean copy of Windows 7 Pro on it. So, I go to get drivers, and I turn up about everything except the audio drivers. Google searching has not resulted in anything. Whatever audio drivers I can find are XP/Vista only. Can I please get some help here? Or can the Vista driver work fine under Windows 7? Thanks for the information!
    WAIT, NEVER MIND!
    For anyone who runs across this very issue, you can obtain the chipset drivers(all of them) HERE:
    http://www.nvidia.com/object/nforce_...bit_15.37.html
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: Cannot Find Audio Drivers- ECS MCP73PT-PM Motherboard
    WAIT, NEVER MIND!
    Just in case of another one , yes , you can force many Vista drivers on Windows 7 , by installing them like any regular drivers , and when Windows 7 refuse installing them at first time , Rebegin the same installing and you'll see the option "Install with compatibility recommended " .. Works most of the time ..
    • Mess
      Beginner question. Did I find a short?? HP dax31mb1aa0 REV A motherboard
      by Mess
      Hi beginner here, so I'm not sure of I've done this right 😅 trying to diagnose my laptop's motherboard (dax31mb1aa0 rev a). I don't quite know how to read the schematic, so I'm attaching the pictures of the motherboard and the measurements.
      I was attempting to measure resistance to GND on inductors. I disconnected motherboard and used "continuity testing" setting on my multimeter. I put black probe to Ground & red probe on an inductor. Did I measure this right? Am I correct to think that 0.3 ohm measurement indicates a short circuit? Thank you for your help!...
      09-15-2024, 09:56 AM
    • Docus
      Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
      by Docus
      Hi everyone 😀,
      I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
      To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
      Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
      1. I already own the exact same model, but its plastic chassis is badly damaged.
      06-10-2025, 04:24 PM
    • rddube
      Scorching hot mosfets on Asus X555Q motherboard - can't find the cause
      by rddube
      I am reading temperatures above 105C (221F) on mosfets PQL8104 and PQL8103 and the board is operating fine until it goes above 105C and then it shuts down. Cpu is ok.
      So can't figure it out. Attached is photo of motherboard, the schematic section showing the culprit mosfets and the whole motherboard schematic. I changed PL8101 thinking it may be bad, same results. I tested out of circuit caps PC8117 and PC8118 and they measure fine.
      So I am at a loss to know what else to check to try and identify the source of the problem
      Any...
      03-08-2024, 08:57 PM
    • Nayla
      Help with resoldering RAM on Surface Pro 7 motherboard, can't find relevant resistors
      by Nayla
      so first thing's first: I'm super aware that this is a very silly undertaking but I love a challenge.
      From my understanding, to ugprade a tablet with soldered RAM, you need to change a series of resistors to tell the computer which config it currently has, as the BIOS doesn't check for it.
      I'm completely alien to reading schematics, but I've been doing my best to read and google every part of the schematic that mentions RAM to try and understand what I need to do.
      I've attached any parts of the schematic I found that I think are relevant. Thus far I haven't...
      01-06-2025, 05:30 PM
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
