Re: <plays taps> 500GB bites the dust...
Well, I trust HDDs when they have a bit more power cycles, that's all I'm saying. That way, it gives me a bit more confidence that the next time I power-cycle the machine, the HDD isn't as likely to come out dead.
Problem with running HDDs 24/7 for too long is that the bearings (be it oldschool ball bearings or the fluid bearings that most HDDs use now) on both the headstack and the spindle motor wear out a bit. And when they wear out, they can screw up the tolerances between the heads and the platters just enough to make the HDD not boot.
When you power OFF the HDD when not in use, you save the HDD some power-on hours at the expense of power cycles. Both POH and power cycles are not good for the HDD when you reach a certain number, so I think it's good to balance them.
In my experience, both the Barracuda ATA IV and 7200.7 don't like high POH. In this case, 16000 POH seems like very little, but it's actually quite a bit for these HDDs. From what I've seen from the 7200.7 line, after 10k to 15k hours, they become much more likely to fail. I think it has to do something with the spindle motor bearings just not being able to handle it. Yours taking much longer to spin up does sound a bit like spindle motor bearings problem. But of course, it could also be a spindle motor driver is faulty on one phase on the circuit board.
Would sure be interesting to investigate.
What I like about these older HDDs like the ATA IV and 7200.7 is they still use the old parallel recording technology. So even if you don't use the HDD in a very long time, the chances of the data going corrupt is much smaller than on the high data density perpendicular technology HDDs of today.
Yes, me neither, which is why I always keep at least several backups of my data.
Also, I want to warn people that flash drives are not very good for long-term backups either. They can die out of the blue too. I had a 4 GB die on me with barely any use. Interesting thing is that it has a Samsung flash IC, so one would think it should have been a reliable flash drive. Yet, it just quit without any prior signs. Interesting thing the OS could still see the flash drive and even still see the files on the flash drive. It just couldn't read anything nor write anything to the flash drive.
So, as always, the most secure way to prevent data loss is to keep multiple backups. And if your most important data isn't too much and can fit on a standard 700 MB CD, then by all means burn it on a CD. I've yet to have a burned CD fail on me.
You are probably right, but I think there are particular brands and models that really do fail more than others. The Toshiba 2.5" laptop HDDs come mind here.
It ran 24/7 for many years. It only has 153 power cycles, though. I don't think it would last so long if it had thousands of cycles. And the bearings on the head stack? Are you making reference to the contact start/stop slider? I wasn't aware that the heads had "bearings" unless you mean the cushion of air that they sit on ("air bearing"), or the material the heads are made of, ferrite wrapped in a wire of coil?
i luv those samsung f3 1tb drives as they are the fastest 1tb drives ever made even faster than the wd caviar black 1tb. because of that, they are perfectly suited for making a 2tb raid 0 array for pure throughput. i use them for heavy bittorrenting on my 250/100mbps fibre line.
