Bad RAM?
    Re: Bad RAM?
    Tried to find the manual to this board, but could only locate the manual for the deluxe version. Anyway reading through the manual (http://dlcdnet.asus.com/pub/ASUS/mb/...n-e_deluxe.pdf) on page 38 I noticed this:
    "If installing the ATIĀ® 9500 or 9700 Pro Series VGA cards, use only the
    card version PN xxx-xxxxx-30 or later, for optimum performance and
    overclocking stability"
    Don't know if your gpu is causing your troubles or not, but I thought I would mention it.
      Re: Bad RAM?
      According to Wikipedia the nforce3 chipset is incompatible with vista.
      https://en.wikipedia.org/wiki/NForce...ncompatibility
        Re: Bad RAM?
        Originally posted by retiredcaps View Post
        What is the date code of the 1.01 BIOS when it boots?
        Asus website has a BIOS 1011 update. It is dated 2006/03/23. Maybe give it a try and re-try with default BIOS settings?
        http://www.asus.com/support/Download/1/20/2/2/8/
        It says it's 1009. Will try a update tomorrow and report back.
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
          Re: Bad RAM?
          According to the release notes/website
          K8N Release BIOS 1010
          Fix default memory timing setting.
          Maybe 1010 fixes the problem you are seeing?
          --- begin sig file ---
          --- end sig file ---
            Re: Bad RAM?
            I don't get it...? Vista I installed on this isn't OEM. It's retail.
            What retail version?
              Re: Bad RAM?
              Ultimate.
              PN 109-A03400-20A is printed on my card. It does work with it though.
              I use drivers that were modded (by a guy named "Fernando") to work on Vista/7 and 8. Feel free to Google them up,they were stable last time I used them.
              Main rig:
              Gigabyte B75M-D3H
              16GB DDR3-1600
              Delux MG760 case
                Re: Bad RAM?
                Just flashed the BIOS - no luck. Still BSODs,although instead of 0x0000001A I get a ntdll.dll blue screen. Again,this does not happen if I replace the 1GB stick with any other stick.
                Main rig:
                Gigabyte B75M-D3H
                16GB DDR3-1600
                Delux MG760 case
                  Re: Bad RAM?
                  Hmm, according to the original manual at
                  https://cdn.badcaps-static.com/pdfs/...d22fce5a99.pdf
                  page 1-11 doesn't even list 1GB sticks. Is there an updated list says the 1GB Kingston is supported?
                  Also, have you tried another DIMM slot or moved the 1GB to another slot?
                    Re: Bad RAM?
                    I think the 1GB stick is newer than the board's manual.
                    Main rig:
                    Gigabyte B75M-D3H
                    16GB DDR3-1600
                    Delux MG760 case
