I have a 64mb Disk on chip that i need to write to.. Im at a loss as how to access it. Does anyone have experiance with these things?
Access Disk On Chip?
Follow the white rabbit.Tags: None -
Re: Access Disk On Chip?
Is this the chip you're talking about?
https://cdn.badcaps-static.com/pdfs/...d4b6dda795.pdf
If so, I know this probably isn't the best solution, but someone on another site had some good ideas.
http://www.electro-tech-online.com/t...module.112240/
They found if you had an old ISA network card that supported a boot ROM, you could insert the DOC into the socket, boot off the card and it'd let you access the data on the chip as a hard drive. Maybe someone else with more knowledge could chime in before you try it though. I'd hate to suggest something that might actually ruin your DiskOnChip.Last edited by Spork Schivago; 04-23-2016, 11:19 PM.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full -
If itll work in a bootrom setup in a sound card, it should work on a NICs boot ROM socket too! Genius! Ill give it a try!Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
I wasn't sure if you just wanted to access it or if you wanted to use it in your own circuit board and access it that way. I hope it works out well for you.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
I'm very interested in the outcome of this thread. I was involved in a data recovery from a DOC with a corrupt NAND chip (inaccessible via DOS), but that involved removing the physical memory chip and dumping its contents in a reader. Hopefully your DOC is fully functional, otherwise I have written a program to restore the file system from a raw NAND dump.
There are some DOC tools which can read and program the DOC, if it is functional.Comment
Did you have any luck Goontron?-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
^ Don't have access to the NIC till saturday...Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
And it's Saturday.Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
Permanently Retired Systems:
Kooky and Kool Systems
sigpicComment
Seems like we have a couple people interested in the outcome here Goontron!-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
outcome was: Cant find the blasted card!Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Hahahahahahahahahahahaha!!!!!!!Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpicComment
I wonder if I slot it into the BIOS ROM socket of my 386 after it is booted, if it'll work.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
No, the system will probably lockup as soon as you remove the BIOS ROM.Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpicComment
Yes, you can shadow/cache the BIOS rom image to RAM, so calls no longer go to the physical ROM IC, but:
Those older systems commonly used an EPROM, not an EEPROM to hold the BIOS program.
(Erasable programmable ROM vs electrically erasable programmable ROM.)
That means no in-system-programming on most (all?) 386 mobos. Flash (EEPROM) didn't become common til late 486/early Pentium MBs. I would not assume a 386 MB's EPROM socket is even wired for such ISP'ing.Last edited by kaboom; 05-01-2016, 05:24 PM."pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!Comment
Catch-22 with those older systems:
That means no in-system-programming on most (all?) 386 mobos. Flash (EEPROM) didn't become common til late 486/early Pentium MBs. I would not assume a 386 MB's EPROM socket is even wired for such ISP'ing.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
You can try hotswapping it for the BIOS ROM in the 386, but keep in mind, all the address lines may not be hooked up.
AMIBIOS was somethink like 64-128 kilobytes back then, so if, say, the lower 8 address lines are hooked up, you'll get repeating "modulo" falses each time you attempt to cycle the addresses as you dump.
You'll end up with repeating data blocks, the size of which depends on how many ADDR lines are actually connected.
Say only 19 lines are connected, and you "walk" the address count to a full 20 bit cycle. You'll only get data (falsely) represented by the lower 19 bits, twice, but it won't be correct data. Which will make you think the dump has more bad bits than it actually might. Better still, if the corruption is in valid data (on the device), but represented above that 20th bit, you'll never see it if you don't address it properly.
Here's an example from the LBA "137GB" limit. Say you have a 200GB HDD. You'll wrap back around after "137GB." So you want to zero-fill this HDD from 6GB (above your data) to 200GB. Now, once 137GB is reached, you wrap back around to 0bytes, and proceed to wipe the drive from zero bytes up to 63GB! Your data, from 0B to 6GB is gone.
While your utility took "200GB" of "steps," (137GB+63GB), there weren't enough bits to cover all actual physical bits/bytes/LBAs on the drive.
It can happen with everything from that, to even NES/SNES/etc ROM dumps. Those were fun, not all ROMS were over 1MB- you can read them OK since they don't use the higher-order ADDR bits, but dump a 4MB cart w/o that bit, and you get four false images of the same lower 1MB worth of addressable bits.
If you can trace the ADDR lines on the ROM skt on the 386 MB, and all appear connected-connected-connected, give it a shot. You may need to use DEBUG to "peek around."
BTW, what's the part number of the device you're trying to dump?
Edit- Looked at datasheet, it's a 32pin device. You will not be able to plug this into a 28pin skt without a "transposition adapter."
EOL it...
Well, this is a dead project now... My nephew just smashed the display!Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
by DynaxSCHi
I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6... -
Long story short:
- dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
- gave the computer to his son a couple years later
- son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
- too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
(seems like the story was not that short)
He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8... -
by TroystainHello, anyone here have updated ezp2023+ chip database in .dat file format.
I need to add w25q256jveq chip but I do not know what data should I type.
I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....11-25-2024, 12:53 AM -
by joesmoe91Hello,
My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights.... -
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... - Loading...
