Slipstreaming 7 drivers.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Quick question. How do you guys slipstream drivers onto a 7 disc? I tried this:
    Code:
    dism /image:c:\test\install /add-driver /driver:c:\test\drivers /recurse
    Which seemed to work for one of the drivers (the modem). However, stuff like video card, didn't get installed. It's an ATI Xpress 1150. I've downloaded the latest from AMD (which is old). When I go to manually install it, it prompts halfway through the installation. It says:
    Windows Security
    Would you like to install this device software?
    Name: ATI Technologies Inc. Display adapters
    blah
    [ ] Always trust software from "ATI Technologies, Inc."
    Install Don't Install
    I'm guessing it's not properly signed? Is there anyways to force these drivers to be installed without disabling driver signature enforcement?
    Or does anyone have any other suggestions on other ways to slipstream the drivers? Thanks!
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • Spork Schivago
    • Mar 2012
    • 4734
    Re: Slipstreaming 7 drivers.
    I think I figured it out. If I pass the /ForceUnsigned option to Dism, I bet it'll work.
    • japlytic
      DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
      by japlytic
      In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
      Tried (only with keyboard/mouse connected):
      • BIOS + database update
      • Using latest Windows 11 image built with official image creation tool
      • Previous setup version for Windows 11 installer
      • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
      • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
      • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
      06-19-2025, 04:59 PM
    • hpw19b
      Default Lenovo LEGION Y530 (NS-B961 Rev 1.0) unavailable to install nvidia drivers
      by hpw19b
      I have recently unlocked supervisor password and flashed bios, now if i look at bios it does not show device name and device S/N. Also lenovo vantage app does not seem to work (i guess its releated to device name and serial)
      Now the nvidia gtx 1060 driver does not want to install. Intel UHD 630 driver installs fine.
      Ive tried: format
      Wiindows update to latest version
      DDU (display driver uninstaller) in safe mode and all the other things i found in google.
      Device manager: This device is not working properly because Windows cannot load the drivers required...
      04-14-2021, 11:52 PM
    • 24gsm
      MacBook Pro A1708 install macos fail
      by 24gsm
      hi to all
      i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
      after enter to recovery and format hdd 1to .
      after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
      can help please
      Serial Number: FVFXP0U0HV2J
      Config Code: HV2J
      Find My Mac: OFF
      04-16-2025, 03:57 AM
    • duwane
      A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
      by duwane
      Hi All.
      Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
      The issue:
      Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
      10-26-2022, 07:02 AM
    • pavithra
      LC6685 based LED drivers
      by pavithra
      I have 50 Chinese constant current isolated LED drivers based on LC6685 IC. 35 drivers are working fine, but there is a slight flickering in the rest of the drivers.
      I have checked the output with oscilloscope and found that there is a slight random voltage fluctuation.
      Is it possible to get the datasheet of LC6685 IC?
      Also highly appreciate if you could let me know what could go wrong....
      04-16-2024, 02:46 AM
