Chrome wont open in Ubuntu 14.04
  • ivtec
    • Dec 2008
    • 1967
    Hi guys i had to reinstall Ubuntu 14.04 and now google chrome wont open,i tried everything, now to install chrome,you have to go to chrome downloads, i do that and ubuntu software opens and i install all good till i try to open it, it just doesn't open at all,any help please.
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Chrome wont open in Ubuntu 14.04
    Gotta delete chrome's config files in your user dir. You'll lose bookmarks.
    http://askubuntu.com/questions/48882...e-not-starting
      • 31094
      run it from a console, you will be able to see the error message.
      btw, it's full of spyware - use the clean version "chromium"
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        That was my initial (one time) impression too and I've given chrome a miss. I'm ok with FF for the time being. It's kinda grown on me. Everything seems full of spyware anymore unless you pay attention though.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Dependency hell!
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • ivtec
            • Dec 2008
            • 1967
            i can't do this on firefox;! at least i don't know how to do it
            OK solved:</p> 1) Open you file browser ("Files" in the launcher)</p> 2) Then go up to "edit" in the top of screen menu bar and select preferences.</p> 3) Then tick "Show hidden and backup files"</p> 4) Go back to your file browser and scroll down to ".local" and open the folder.</p> 5) Then open "share" folder.</p> 6) Open "applications" folder.</p> 7) Select every folder with chrome in it's name and trash (empty trash)</p> 8) Open the launcher "Search your computer and online sources" App in the launcher and search for Google Chrome and launch... </p> ...problem solved! – DiGwork Jun 27 '14 at 13:07
            deleting all files in /home/USERNAME/.config/google-chrome/ which forces Google Chrome to regenerate all configuration and profile files. You should be able to do this with a single command:
            rm ~/.config/google-chrome/*
            when i type this in the terminal i get this;
            frank@frank-ThinkCentre-M71e:~$ sudo rm ~/.config/google-chrome/*
            [sudo] password for frank:
            rm: cannot remove ‘/home/frank/.config/google-chrome/Avatars’: Is a directory
            rm: cannot remove ‘/home/frank/.config/google-chrome/Crash Reports’: Is a directory
            rm: cannot remove ‘/home/frank/.config/google-chrome/Default’: Is a directory
            rm: cannot remove ‘/home/frank/.config/google-chrome/Dictionaries’: Is a directory
            rm: cannot remove ‘/home/frank/.config/google-chrome/EVWhitelist’: Is a directory
            rm: cannot remove ‘/home/frank/.config/google-chrome/PepperFlash’: Is a directory
            rm: cannot remove ‘/home/frank/.config/google-chrome/pnacl’: Is a directory
            rm: cannot remove ‘/home/frank/.config/google-chrome/ShaderCache’: Is a directory
              • 31094
              rm -rd --force ~/.config/google-chrome/*
              you need to specify the options.
              r = recurse into subdirectory's
              d = delete
              force = dont ask y/n for each file
              • ivtec
                • Dec 2008
                • 1967
                d = delete
                thanks stj; can you believe this! the chrome page was hidden on the desktop all along,it was moved to one side under the unity apps,i've just moved the mouse under desktop launcher apps.
