Adding Caps to a socket 478 MB
  • M_H
    • Feb 2005
    Hi Everyone,
    Recently I have been reading in another forum about adding caps in parallel to S478 motherboards in preparation to overclock the power robbing Prescott CPU.
    The reason for this mod is to stabalize the power supply the the vcore and the board itself.
    I cannot find anyone who can give me a reasonable explanation on how exactly to go about this.
    If I was to add these caps would I use the same voltage and capacitance as the existing ones on the board?
    I know I would solder them to the existing connections and mod the tray to make the board fit.
    By the way the board is an ASUS P4C800e-Deluxe
  • MD Willington
    • Sep 2004
    • 702
    Caps placed in parallel will add to the capacitance:
    2-2200uF caps in parallel will = 4400uF
    2-2200uF caps in series will = 1100uF
    http://www.allaboutcircuits.com/vol_1/chpt_13/4.html
    That may mess up the circuit since it is probably designed for only a certain range of capacitance.
    MD
    Ya'll think us folk from the country's real funny-like, dontcha?
    The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
    • bushytails
      Moderator
      • Dec 2004
      • 217
      You can either solder them to the back like you suggested, in which case it's a trivial soldering job, but you have to modify the case, or you can desolder the current capacitors and replace them with larger ones. (larger capacity, and not surprisingly, larger size). This would require a bit more soldering skill, but won't require modifications to the case. Make sure you buy low-ESR caps! Using a high-esr cap twice the size is still probably worse than the stock caps...
      If you're putting them in parallel, it doesn't matter what the capacitance of the new ones is, as long as the voltage rating is sufficient. Also make sure you use the correct polarity; I've heard of people getting confused when working on the back side of the board, and exploding their capacitors...
      --Randy
      • M_H
        • Feb 2005
        I'm not sure that a larger size cap would fit on the board.
        Sorry I'm a bit new to all this.
        If I attach them in parrallel should I use the same voltage rating and ?????? (suggestions for capacitance)
        Yes I have read to use low ESR caps
        • spike93
          Xbox 360 parallel caps
          by spike93
          I'm probably going to ask a very noob question but after many readings and videos I'm still unsure on the answer.
          I've broken one of the caps around the gpu of an xbox 360 by overheating it. In the forum I've found this thread where the user had exactly my situation (same console version and same broken caps): https://www.badcaps.net/forum/showthread.php?t=24983
          The difference is that I've broken only one of the Rubycon caps (or at least that's what I can tell from a visual inspection). Now I'm planning to use a solid capacitor as replacement,...
          02-18-2023, 10:45 AM
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • SwedishDiesel
          Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
          by SwedishDiesel
          Howdy folks,
          I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
          10-30-2021, 12:47 AM
        • madan1
          DALI SUB E-12F class D, fluctuating power rail
          by madan1
          Good day everyone.
          I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
          The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
          The normal value of the positive and negative power rails is +/- 43V.
          The positive rail stays...
          10-15-2025, 10:33 AM
