need options on IDE issue
  • yonu
    • Nov 2007
    • 138
    OK here is the problem I am having I have a Foxconn - WINFAST 748K7AA motherboard and when i hook up the drive it says no 80wire ide cable is used however they are 80wire cables any thoughts on this? I have tryed a couple of different cables with no luck
    Thanks,
    yonu
  • gdement
    • Jan 2007
    • 690
    Re: need options on IDE issue
    I don't know anything about that board specifically, but 80wire cables are fragile. Are the cables you tried new, or are they old ones? They use solid core wire, which deteriorates after it gets bent too many times.
    But I'm probably on the wrong track. I think there's a specific pin responsible for detecting an 80wire cable, and it's unlikely both cables would be broken in exactly the same place. My only guess would be a bad solder joint on the board.
    • kikkoman
      • Jul 2007
      • 691
      I've seen 80wire cables that are made of stranded wire, too. Either way, they're fragile and too much tension can easily damage them (especially at the edges).
      could be a ground/shielding issue as well.
      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        What is the drive?
        Mann-Made Global Warming.
        - Dr Seuss
        • yonu
          • Nov 2007
          • 138
          it is actually 4 drives
          they are
          Maxtor 2B020H1
          Maxtor 6L200R0
          Maxtor 6L300R0
          HP DVD Writer 630c
          and both IDE channels give the issue
          and one cable is new the other one is old
          Thanks,
          yonu
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Know what.
            I would take a close look at your capacitors.
            Particularly those near your chipset and IDE connectors.
            I had a board with one bad cap in the IDE that if I connected any drive to the second IDE port then it would detect no drives at all present on either connector.
            Disconnect the second IDE port and it worked fine using the first port.
            [That board still lives in my ever growing 'to do' box.]
            - Dr Seuss
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              Hey! You've got one of those, too, eh? Mine is full of donated boards that have no urgency in their recap. And, they're boards that I likely will not profit from, and so do not see the need to spend the money in caps to fix them.
              Ludicrous gibs!
              • yonu
                • Nov 2007
                • 138
                Will look but they all looked find when I installed the board thanks hadn't even thought of that
                • yonu
                  • Nov 2007
                  • 138
                  well Guys I feel real stupid and this is also the last time I chance IDE cables at 2 in the morning turns out they were 40wire cables the system I has having trouble with is the server for my home automation and whole house audio so I only work on it after everyone has gone to bed so needless to say I walk into the server closet and look on the shelf are 2 80wire cables so i slide the cover off the case and look and yeap there are 2 40 wire cables in the system apparently when I changed out a drive a couple weeks ago I screwed up and put the old cables back in.
                  so i feel extremly stupid,
                  Thanks for the help,
                  yonu
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    No worries.
                    Everyone has days like that.
                    - Dr Seuss
                    • Tr0ll
                      by Tr0ll
                      Original T-con:
                      First replacement T-con:
                      10-07-2023, 07:48 PM
                      Acer Aspire A317-53-52WQ + 17.3" Options Pack Care Gold Notebook 3 Specification for Upgrade or Repair
                      This specification for the Acer Aspire A317-53-52WQ + 17.3" Options Pack Care Gold Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-53-52WQ + 17.3" Options Pack Care Gold boardview and A317-53-52WQ + 17.3" Options Pack Care Gold schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                      09-07-2024, 03:10 AM
                      Acer Aspire A317-53-32Z4 + 17.3" Options Pack Care Gold Notebook 3 Specification for Upgrade or Repair
                      This specification for the Acer Aspire A317-53-32Z4 + 17.3" Options Pack Care Gold Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-53-32Z4 + 17.3" Options Pack Care Gold boardview and A317-53-32Z4 + 17.3" Options Pack Care Gold schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                      Acer Aspire A317-53-37SZ + 17.3" Options Pack Care Gold Notebook 3 Specification for Upgrade or Repair
                      This specification for the Acer Aspire A317-53-37SZ + 17.3" Options Pack Care Gold Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-53-37SZ + 17.3" Options Pack Care Gold boardview and A317-53-37SZ + 17.3" Options Pack Care Gold schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                      Acer Aspire A317-53-369X + 17.3" Options Pack Care Gold Notebook 3 Specification for Upgrade or Repair
                      This specification for the Acer Aspire A317-53-369X + 17.3" Options Pack Care Gold Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-53-369X + 17.3" Options Pack Care Gold boardview and A317-53-369X + 17.3" Options Pack Care Gold schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
