Re: Western Digital Hard Drive Not Bootable
Maybe.
Look here if you haven't yet:
http://www.forensicswiki.org/wiki/DCO_and_HPA
Maybe.
:~$ sudo hdparm -N /dev/sdb /dev/sdb: max sectors = 488397168/488397168, HPA is disabled :~$ sudo hdparm --dco-identify /dev/sdb /dev/sdb: DCO Revision: 0x0001 The following features can be selectively disabled via DCO: Transfer modes: udma0 udma1 udma2 udma3 udma4 udma5 udma6(?) Real max sectors: 488397168 ATA command/feature sets: security AAM HPA
:~$ sudo hdparm -I /dev/sdb [sudo] password for mike: /dev/sdb: ATA device, with non-removable media Model Number: WDC WD2500JD-57HBC0 Serial Number: WD-WCAL75730506 Firmware Revision: 21.02J21 Standards: Supported: 6 5 4 Likely used: 8 Configuration: Logical max current cylinders 16383 16383 heads 16 16 sectors/track 63 63 -- CHS current addressable sectors: 16514064 LBA user addressable sectors: 268435455 LBA48 user addressable sectors: 488397168 Logical/Physical Sector size: 512 bytes device size with M = 1024*1024: 238475 MBytes device size with M = 1000*1000: 250059 MBytes (250 GB) cache/buffer size = 8192 KBytes (type=DualPortCache) Capabilities: LBA, IORDY(can be disabled) Standby timer values: spec'd by Standard, with device specific minimum R/W multiple sector transfer: Max = 16 Current = 0 Recommended acoustic management value: 128, current value: 128 DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6 Cycle time: min=120ns recommended=120ns PIO: pio0 pio1 pio2 pio3 pio4 Cycle time: no flow control=120ns IORDY flow control=120ns Commands/features: Enabled Supported: * SMART feature set Security Mode feature set * Power Management feature set * Write cache * Look-ahead * Host Protected Area feature set * WRITE_BUFFER command * READ_BUFFER command * DOWNLOAD_MICROCODE * Power-Up In Standby feature set * SET_FEATURES required to spinup after power up SET_MAX security extension * Automatic Acoustic Management feature set * 48-bit Address feature set * Device Configuration Overlay feature set * Mandatory FLUSH_CACHE * FLUSH_CACHE_EXT * SMART error logging * SMART self-test * Gen1 signaling speed (1.5Gb/s) * Host-initiated interface power management * SMART Command Transport (SCT) feature set * SCT Read/Write Long (AC1), obsolete * SCT Write Same (AC2) * SCT Error Recovery Control (AC3) * SCT Features Control (AC4) * SCT Data Tables (AC5) Security: Master password revision code = 65534 supported not enabled not locked not frozen not expired: security count not supported: enhanced erase Checksum: correct
smartctl 6.2 2013-07-26 r3841 [x86_64-linux-3.16.0-24-generic] (local build) Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: ASMedia Product: AS2115 Revision: 0 User Capacity: 250,059,350,016 bytes [250 GB] Logical block size: 512 bytes Logical Unit id: 0x5000000000000001 Serial number: 00000000000000000000 Device type: disk Local Time is: Wed Mar 4 11:52:31 2015 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Disabled or Not Supported === START OF READ SMART DATA SECTION === SMART Health Status: OK Error Counter logging not supported Device does not support Self Test logging
