Western Digital Hard Drive Not Bootable
    Re: Western Digital Hard Drive Not Bootable
    Maybe.
    Look here if you haven't yet:
    http://www.forensicswiki.org/wiki/DCO_and_HPA
      Originally posted by SteveNielsen View Post
      Maybe.
      I did see that already. It doesn't say whether having DCO Revision: 0x0001 means you HAVE it but I assume it does ?? Strangely it doesn't tell you how to get rid of it if you do.
        hdparm --dco-restore /dev/sdX is what removes this. this one should work over USB.
        Follow the white rabbit.
          Let me post the output of the dco-identify command see what you think. Brb
            Code:
            :~$ sudo hdparm -N /dev/sdb
            /dev/sdb:
             max sectors  = 488397168/488397168, HPA is disabled
            :~$ sudo hdparm --dco-identify /dev/sdb
            /dev/sdb:
            The following features can be selectively disabled via DCO:
            	Transfer modes:
            		 udma0 udma1 udma2 udma3 udma4 udma5 udma6(?)
            	Real max sectors: 488397168
            	ATA command/feature sets:
            		 security AAM HPA
            Remember these are over usb
              Code:
              /dev/sdb:
              /dev/sdb:
              	Transfer modes:
              		 security AAM HPA
              i would issue hdparm --dco-restore /dev/sdX just because AAM can reduce the speed of the drive significantly. (but does make it quieter)
                And this can be done over USB safely ?
                  yes. dco commands are on the minimal list of commands required for operation. it wont damage if it does error anyway.
                    Ok before I do would it be useful to see the output of the -I (information) command ?
                      yes, the output of hdparm -I and smartctl -ax would be helpful. it should give me all the info on the drive minus pictures of the dust
                        Code:
                        :~$ sudo hdparm -I /dev/sdb
                        [sudo] password for mike:
                        /dev/sdb:
                        ATA device, with non-removable media
                        	Model Number:    WDC WD2500JD-57HBC0
                        	Serial Number:   WD-WCAL75730506
                        	Firmware Revision: 21.02J21
                        Standards:
                        	Supported: 6 5 4
                        	Likely used: 8
                        Configuration:
                        	Logical		max	current
                        	cylinders	16383	16383
                        	heads		16	16
                        	sectors/track	63	63
                        	CHS current addressable sectors:  16514064
                        	LBA  user addressable sectors: 268435455
                        	LBA48 user addressable sectors: 488397168
                        	Logical/Physical Sector size:      512 bytes
                        	device size with M = 1024*1024:   238475 MBytes
                        	device size with M = 1000*1000:   250059 MBytes (250 GB)
                        	cache/buffer size = 8192 KBytes (type=DualPortCache)
                        Capabilities:
                        	LBA, IORDY(can be disabled)
                        	Standby timer values: spec'd by Standard, with device specific minimum
                        	R/W multiple sector transfer: Max = 16	Current = 0
                        	Recommended acoustic management value: 128, current value: 128
                        	DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
                        	   Cycle time: min=120ns recommended=120ns
                        	PIO: pio0 pio1 pio2 pio3 pio4
                        	   Cycle time: no flow control=120ns IORDY flow control=120ns
                        Commands/features:
                        	Enabled	Supported:
                        	  *	SMART feature set
                        	  	Security Mode feature set
                        	  *	Power Management feature set
                        	  *	Write cache
                        	  *	Look-ahead
                        	  *	Host Protected Area feature set
                        	  *	WRITE_BUFFER command
                        	  *	READ_BUFFER command
                        	  *	DOWNLOAD_MICROCODE
                        	  *	Power-Up In Standby feature set
                        	  *	SET_FEATURES required to spinup after power up
                        	  	SET_MAX security extension
                        	  *	Automatic Acoustic Management feature set
                        	  *	48-bit Address feature set
                        	  *	Device Configuration Overlay feature set
                        	  *	Mandatory FLUSH_CACHE
                        	  *	FLUSH_CACHE_EXT
                        	  *	SMART error logging
                        	  *	SMART self-test
                        	  *	Gen1 signaling speed (1.5Gb/s)
                        	  *	Host-initiated interface power management
                        	  *	SMART Command Transport (SCT) feature set
                        	  *	SCT Read/Write Long (AC1), obsolete
                        	  *	SCT Write Same (AC2)
                        	  *	SCT Error Recovery Control (AC3)
                        	  *	SCT Features Control (AC4)
                        	  *	SCT Data Tables (AC5)
                        Security:
                        	Master password revision code = 65534
                        		supported
                        	not	enabled
                        	not	locked
                        	not	frozen
                        	not	expired: security count
                        	not	supported: enhanced erase
                        Checksum: correct
                        Well, there it is anyway. I see no reference to "Sata" is that normal ?
                          How do I use the smartctl command exactly ?
                            Code:
                            /dev/sdb:
                            Standards:
                            	Supported: 6 5 4
                            	Likely used: 8
                            Configuration:
                            	Logical		max	current
                            	heads		16	16
                            	sectors/track	63	63
                            Capabilities:
                            Commands/features:
                            	Enabled	Supported:
                            	  *	SMART feature set
                            	  *	Write cache
                            	  *	Look-ahead
                            	  *	FLUSH_CACHE_EXT
                            	  *	SMART self-test
                            Security:
                            		supported
                            	not	enabled
                            	not	locked
                            	not	frozen
                            Checksum: correct
                            Sata is handled by the kernel SCSI subsystem.
                            sudo smartctl -ax /dev/sdX
                            are you on OSX or Linux?
                              Ubuntu
                                Ubuntu
                                should have asked this sooner.... is smartmontools installed?
                                  Yes but smartctl errors with "Unknown USB Bridge"
                                    thats an issue..... you have one of the bad bridges.
                                      I also ran GSmartControl and there's not much there. Serial number zero'd etc..
                                      Code:
                                      smartctl 6.2 2013-07-26 r3841 [x86_64-linux-3.16.0-24-generic] (local build)
                                      Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
                                      === START OF INFORMATION SECTION ===
                                      Vendor:        ASMedia
                                      Product:       AS2115
                                      Revision:       0
                                      User Capacity:    250,059,350,016 bytes [250 GB]
                                      Logical block size:  512 bytes
                                      Logical Unit id:   0x5000000000000001
                                      Serial number:    00000000000000000000
                                      Device type:     disk
                                      Local Time is:    Wed Mar 4 11:52:31 2015 EST
                                      SMART support is:   Available - device has SMART capability.
                                      SMART support is:   Enabled
                                      Temperature Warning: Disabled or Not Supported
                                      === START OF READ SMART DATA SECTION ===
                                      SMART Health Status: OK
                                      Error Counter logging not supported
                                      Device does not support Self Test logging
                                        You can't do it over that USB interface then. You'll need to go direct to SATA connection or a supported USB bridge.
                                          Code:
                                          Vendor:        ASMedia
                                          Product:       AS2115
                                          Revision:       0
                                          Device type:     disk
                                          OK, issue dco restore.... We are not getting anything SMART without being on the internal SATA.
