com1 not working
  • mohomane
    • Aug 2013
    • 12
    • south-africa
    com1 not working
    hi, i have been using my ponyprog and self made programmer based on 5.1 zener diodes and 4148 diodes now my hardware is not working ,i want a drawing for ponyprog programmer based on diodes and zeners.
  • Dvsr
    On M-Audio AV40 active studio speaker's two zener diodes get really hot.
    by Dvsr
    Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
    I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
    After replacing the caps I started testing out the speaker. It seemed...
    09-10-2025, 10:20 AM
  • caspian
    What Zener Diodes on a Linear Power Supply
    by caspian
    Dear members,
    I have a linear variable power supply with unknown brand name that I used for voltage injection.
    Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
    In addition, I discovered that its zener diodes are defective.
    I can replace the burned transistors.
    But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
    Therefore, I cannot replace the zener diodes.
    I do not want to test the zener diodes in a test circuit to discover their model or value.
    no schematics are available...
    05-26-2025, 12:38 PM
  • STKR123
    The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
    by STKR123
    Greetings badcaps community,
    I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
    So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
    Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
    I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
    These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
    I learned that desoldering...
    10-29-2024, 06:03 AM
  • Teeheeze
    RT809H Programmer Firmware Corrupted
    by Teeheeze
    This is a shot in the dark, but I was just using my RT809H programmer and it got stuck in a certain state so I power cycled it. Now, the device LED just flashes quickly and does not connect to the software. I've tried to update the BIOS of it and it fails. I went so far as to remove the ROM from the programmer itself but it's some weird chip (I believe ATMEL, but I can't find any datasheet on it) so I've been unable to read the BIN from it w/ my other programmer. Chip has ATMLHC4C56BM CN written on it (I think). I'll upload an image. I have the programmer's BIN ready to program it manually. Anyone...
    02-13-2025, 04:51 PM
  • H34TO
    ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
    by H34TO
    Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
    06-17-2025, 07:17 AM
