BadBIOS/EEPROM chip
  • Crapacitance
    • Jun 2014
    • England, United Kingdom
    BadBIOS/EEPROM chip
    I badly flashed a BIOS chip. Bought a CH341A EEPROM programmer and 8 pin test clip, attached it to the chip on the motherboard and read it - returned values were all 00 00 00 00, attempted erase but when checking if it was blank I got an error message saying "The chips are not null", when trying to write the original BIOS.bin or anything at all to it I got "The chip and contents are in disagreement."
    The program I am using is called "CH341A Programmer"
    Is the EEPROM chip broken and needs replacing?
    Can I force the chip to reset itself to NULL status, perhaps by shorting two of the contacts and applying power to the motherboard?
    Motherboard is M2N68-LA Narra3 (Hewlett Packard)
    EEPROM is Winbond W25x80VSIG (Phoenix BIOS)
  • Agent24
    I see dead caps
    • Oct 2007
    • 4981
    • New Zealand
    Re: BadBIOS/EEPROM chip
    You can reset the BIOS settings but there is no way to blank a chip without the proper command through the SPI interface.
    I would suspect it may be because you are trying to do it while the chip is in-circuit.
    -David VanHorn
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • DynaxSC
      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
      by DynaxSC
      Hi
      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
      08-04-2025, 12:20 PM
    • pengamat_hebat
      Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
      by pengamat_hebat
      I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
      Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
      However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
      I also tried applying 3.3V to pin 3, but it still didn't work.
      I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
      03-25-2025, 04:13 AM
      How to add chip support to NeoProgrammer software for the CH341A Programmer
      by SMDFlea
      Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
      and once you do find them there`s a few crucial steps missing.
      Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
      Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
      After adding the chip save the xml file and copy it to the root directory of the...
      05-26-2024, 07:15 AM
    • BMCappelletti
      Asus Chromebox CN62 - wrong chip put on BIOS reader
      by BMCappelletti
      Long story short:
      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
      - gave the computer to his son a couple years later
      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
      (seems like the story was not that short)
      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
      01-08-2025, 07:27 PM
