Seagate burning
  • johndi
    • Sep 2006
    • 12
    Seagate burning
    This Seagate ST3160023AS HDD (160GB, 7200rpm) has a clearly burned part (which I don't know what it is).
    I would be grateful if someone could tell me if the HDD can be repaired by replacing the part, and if so were can I obtain such part.
    TIA
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Seagate burning
    doesnt look burnt
    • Spacedye69
      • Nov 2005
      • 698
      • US
      Re: Seagate burning
      What is wrong with it(what is it doing, or not doing)?
      • Maxxarcade
        • Jul 2006
        • 973
        Re: Seagate burning
        That looks like an epoxy sealed inductor. What you see is just the epoxy around the top lid. You'd have to try pretty hard to melt one of those before your power supply shuts down.
        What is wrong with the drive? If it still spins up and does not make any clanking noises, check it for bad sectors with HDAT2. You can get it at www.hdat2.com. You can also use this program to check the SMART log and other things. I use it at work quite a bit and have fixed many drives with it.
        Also, Seagate usually has 5 year warranties, so send it in if it is not that old
        • johndi
          • Sep 2006
          • 12
          Re: Seagate burning
          Something has burned in the drive on account of the smoke and smell it produced.
          After that the drive went dead without noticeable spin.
          I examined it carefully and the only part apparently burned was the one I have indicated.
          I suspect the problem was caused by trying to power it up by mistake with a 5V line instead of 12V, but don't understand how that could burn the drive.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            Re: Seagate burning
            how did you do that?
            maybe you reversed polarity?
            there might be other stuff on the rear of that board
            • johndi
              • Sep 2006
              • 12
              Re: Seagate burning
              The (probable) mistake was caused by a mess of cables and fans in a crowded case.
              What do you mean by “there might be other stuff on the rear of that board” ? Should I try to screw out the HDD's board?
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                Re: Seagate burning
                these guys are the hdd experts http://forum.hddguru.com/
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Re: Seagate burning
                  If you had data you needed on the drive you can always buy a new PCB (well, an exactly the same drive, firmware and all) and then just swap the PCB...
                  Note that the drives list of bad sectors will be invalid so it will not be safe to use the drive after this, only to get the data off it...
                  That is if the motor was not damaged of course...
                  • johndi
                    • Sep 2006
                    • 12
                    Re: Seagate burning
                    Thanks, posted there and already got a helpful answer.
                    • johndi
                      • Sep 2006
                      • 12
                      Re: Seagate burning
                      [QUOTE=Per Hansson]If you had data you needed on the drive you can always buy a new PCB (well, an exactly the same drive, firmware and all) and then just swap the PCB...
                      Forgive me to ask but what is a PCB, where can I buy one and what can I do with it?
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        Re: Seagate burning
                        I mean the circuit board on the harddrive itself
                        If it's dead it can be swapped for another one...
                        PCB=Printed Circuit Board
                        • Tom41
                          • Oct 2005
                          • 336
                          • England
                          Re: Seagate burning
                          Were you trying to put the molex connector into the drive and feeling if it had gone in? I often do that if the socket is in such a position that it's hard to look at while inserting the connector. If it doesn't want to go in, I turn it round so that it does fit.
                          However, if you are doing that while the PSU is on, the pins on the molex will be live with DC current from the PSU, and the pins may make contact briefly when you are trying to put it in upside down.
                          Unfortunately, even a split second of having 12v pumped into the 5v line is enough to blow components or fuses - this happened to me with a very old 2X CD-ROM drive that I was testing
                          You know there's something wrong when you open your PC and it has vented Rubycons...
                          • johndi
                            • Sep 2006
                            • 12
                            Re: Seagate burning
                            The bad news is that on http://forum.hddguru.com/dead-seagate-vt7018.html I've found that the problem may go way beyond the burned inductor, so replacing it won't probably do.
                            The good news is that Seagate has confirmed that the HDD is still under their 5 year warranty (thanks Maxxarcade), so I am sending it for RMA.
                              HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                              This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                              09-12-2024, 02:00 PM
                              HP ProBook 450 G7 + Seagate Expansion 1TB Notebook 400 Specification for Upgrade or Repair
                              This specification for the HP ProBook 450 G7 + Seagate Expansion 1TB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + Seagate Expansion 1TB boardview and 450 G7 + Seagate Expansion 1TB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                              09-06-2024, 08:10 PM
                              HP ProBook 430 G7 + Seagate Expansion 1TB Notebook 400 Specification for Upgrade or Repair
                              This specification for the HP ProBook 430 G7 + Seagate Expansion 1TB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Seagate Expansion 1TB boardview and 430 G7 + Seagate Expansion 1TB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
