Auto Power-On After Outages: Advice?
  • cassius
    • Aug 2021
    • India
    I'm looking for ways to ensure that my desktop computer automatically powers on once the power is restored after an outage. I've heard suggestions about shorting the front panel I/O connector on the motherboard or shorting the SMPS 20/24 pin to accomplish this. However, I'm uncertain if these methods are both effective and safe.
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3266
    • Singapore
    the bios should have an option to always power on after ac back or after ac is restored. however, the option can be called by many different names by different motherboard manufacturers and not every board may have such functionality. consult your motherboard manual for more info.
    shorting the board's power header wont work. the power header button is a push to on button type, therefore shorting will just cause the board to power on and off repeatedly every several seconds or so.
    shorting the green wire to any black wire on the main atx connector can work but short circuit protection is setup differently depending on the psu manufacturer and depending on the model and ic chip used. therefore, in some cases, shorting the green wire *might* cause the short circuit protection to not work and could result in a fire. so i dont recommend it if the computer is going to be left unattended for long hours or unless u are sure and have tested that the short circuit protection requires the ac power to be removed to reset the psu's short circuit protection trip. then it may be ok to short the green wire on the main atx connector if the board's bios lacks the option to always power on after ac is back.
      • Jul 2011
      • 6070
      I personally do not recommend doing this even if your computer has this feature because first of all the computer did shut down properly and a lot of times it requires some type of intervention on the user either reboot or continue to load windows which may or might not work correctly your better option would be to use a battery backup and get one big enough for you to safely shutdown your computer when you do not have normal operating power
      • cassius
        • Aug 2021
        • India
        Could you please explain how to test it?
        • Country Cat
          Local Barn Cat
          • Apr 2024
          Most systems will have an option in the BIOS for that (usually listed under "Boot" or "Power" settings), but I agree with Sam's advice on using some sort of uninterruptible power supply as a fallback.
          • bembeno
            lenovo z580 poweron for 1 sec then auto poweroff
            by bembeno
            lenovo z580 when press power switch it poweron for 1 sec then auto poweroff what should i check in this case
            motherboard no : da0lz3mb6g0 rev g
            09-07-2022, 09:06 AM
          • shouri
            Dell latitude e5490 auto restart
            by shouri
            Hi guys, can someone help me?
            I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
            Board model is dm70 la-f401p rev:1.0 2017-09-20.
            At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
            After a few days test, is seems ok.
            Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
            12-10-2024, 09:27 PM
          • theflyingsquirrel
            Chromebook USB-C no longer recognized USB devices after shorting
            by theflyingsquirrel
            I have a Samsung chromebook Pro and one of the USB-C port have something inside and was shorting. The particular thing look like a loose soldering debris. It was at a bit off middle so I think it was shorting the vbus and data pin. I ended up desoldering the whole usbc port and removed it. Upon removoing the usbc port, the chromebook boot again. I can charge with the remaining usbc port (now I found out that when I charge with higher power charger, it does not work), but I cannot get it to recognize any USB stick I plug in. May be the handshake is gone? In the pictures, you can still see the USBC...
            02-25-2025, 09:23 AM
          • Ady2017
            SMD fuse soldering advice please
            by Ady2017
            Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
            11-07-2025, 12:03 PM
          • classicandy
            Lenovo G50-80 Auto Power On when AC is detected
            by classicandy
            Hi Everyone,
            I have a Lenovo G50-80 that auto powers On when AC (Charger) is connected. I have checked the BIOS settings and there is no option to turn On or Off that feature as it is in some HP EliteBooks. I did update the BIOS and still same.
            I then flashed the BIOS with a different bin file I downloaded here, It worked (didn't auto power on) for some time (after testing up to 5 times) but has now started again to auto power on when AC is connected.
            The CMOS battery voltage is 3v. I have also tested with two main batteries as well. I would be glad if anyone...
            03-21-2024, 05:48 AM
