Mystery Resistor?
  • foxd01
    • Apr 2016
    • 3
    • England
    Mystery Resistor?
    Hello folks, I'm trying to fix an ATX power supply, among other problems it has a blow resistor with markings that don't make sense to any of the calculators I've tried.
    I'm reading it as red, red, silver, gold, green.
    It is a large resistor (15.5mm) on the high voltage circuit.
    Here is a huge picture - can anyone help me with the resistance and wattage values?
    Thanks for any help.
    Click image for larger version  Name:	mystery resistor .jpg Views:	36 Size:	1.63 MB ID:	3193982
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
Name:	5 Band Resistor Color Code.png
Name:	Resistor Power Rating and the Power of Resistors.png
    Example: If the source voltage is 5V, and the resistance is 100Ω, what minimum power rating must the resistor have?
    P = 5^2 / 100Ω = 0.25W = 1/4 watt.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • jiroy
      • Jun 2016
      • 2416
      • Lebanon
      The problem here is most online Resistor calculators explain everything , well , everything except how to draw a decimal . Maybe some when reading this will put a fix or something explanatory ..
      Anyway , the general idea is , when you see 2 consecutive gold color , it means its x,x ohms , higher than zero . like for an example : Red , Red , Gold , Gold ==> 2.2 ohms . When you see 2 consecutive Silver Gold , it means 0.xx , example : Red , Red , Silver , Gold ==> 0.22 ohms . The remaining color , if there is , will be for tolerance .
      • jinu_j
        by jinu_j
        Hi
        05-03-2025, 10:51 PM
      • mikey5791
        Need help to replace burned resistor in 350w atx psu
        by mikey5791
        Hi to all forum members,
        Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
        The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
        Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
        Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
        12-26-2024, 04:55 AM
        Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
        This specification for the Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2H0 + Pack Gold Acer 14'' boardview and SF114-34-P2H0 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
        09-07-2024, 03:10 AM
        Acer Swift SF114-34-P25P + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
        This specification for the Acer Swift SF114-34-P25P + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P25P + Pack Gold Acer 14'' boardview and SF114-34-P25P + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
        Acer Swift SF114-34-P2H0 + Pack Gold Notebook 1 Specification for Upgrade or Repair
        This specification for the Acer Swift SF114-34-P2H0 + Pack Gold Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2H0 + Pack Gold boardview and SF114-34-P2H0 + Pack Gold schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
        09-07-2024, 02:20 AM
