Card Reader Suggestions
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    My main rig's Atech Flash XM-5U has been crapping out on me lately... it will freeze up, and being internal, the only way around that is to reboot (or open the case and replug it). Grr....
    Usually Atech makes good readers... this one is cheaper though, so that may be part of it.
    This time, I want a good internal 3.5" reader. SDHC and Compact flash are musts, XD is huge plus as well. Must have a front USB 2.0 port as well. I don't need any other ports or the like. My case is black so a black bezel option is a must.
    Suggestions for a decent internal card reader?
    sigpic
    (Insert witty quote here)
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Card Reader Suggestions
    Check pm
    • tmiha71
      • Apr 2010
      • 130
      Check PSU, check MBO, probably excessive (over or under ) voltage on +5V rail...
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Originally posted by shovenose
        Check pm
        Nope, I need usb 2.0, not 3.0.
        None of my other USB devices seem to have issues... but last I checked my 5v was good. when it's off the drive is still lit up... so usb must be also hooked to 5vsb on the this rig (it's a tyan K8WE).
        sigpic
        • tmiha71
          • Apr 2010
          • 130
          Some mbo's switch their (ALL?) load from standby 5V - to +5V rail, when they're on...
            Alcor AU6368 USB 2.0 Flash Memory Card Reader Datasheet
            The AU6368 is an integrated single chip memory card reader controller specially designed for notebook, hand-held and other PC peripheral devices, which require fewer components for small PCB area. It supports a widely used flash memory card such as CF, MD, SMC, xD Picture Card, MS, MS Pro, MS Duo, SD and MMC. It can be used as removable storage disks in enormous data exchange applications between PC and PC or PC and various consumer electronic appliances.
            The AU6368 reads digital content saved on memory card that user captured with the portable device such as notebook, digital camera,...
            10-23-2024, 03:26 AM
          • vbogoev
            Read eMMC chip using SD card reader
            by vbogoev
            I found several sources where guys successfully read eMMC chip using a SD card reader. I was interested to try it, just to practice micro soldering, but for some reason I am unable to read the chip. The chip is known working one (desoldered from an old working device) model Samsung KLM8G1WE4A-A001. The card reader is Transcend USB 3.0. So basically I've connected everything as it is described in the schematic, but the sd card reader didn't even start to blink. I am not sure what I am missing, so I'll appreciate some help... ...
            07-08-2023, 10:47 AM
          • Technomancer
            Nintendo 2DS SD Card Reader issue. Problem on the clock line?
            by Technomancer
            I have a 2DS that I am working on that has a problem reading SD cards. It knows that card is in the slot (which, means the detect pin is working anyway) but it says it can’t read the card.
            Here is what I have done so far:
            -Tried SD card in another 2DS and on PC, works great.
            -Tried piggybacking another SD card slot (just so I didn’t have to take the other one off), same issue.
            -Compared voltage drop readings from a working 2DS to the faulty one. All reads are very close except one, the 7th pin from the left, with the pins closest to you, which I believe...
            06-07-2022, 09:01 PM
            Apple MacBook Pro A1212 820-2060 USB Audio Card Reader Power Boardview
            Apple MacBook Pro A1212 820-2060 USB Audio Card Reader Power Boardview...
            10-27-2024, 07:21 AM
          • Christos Tsiligiannis
            Marian Trace Alpha sound card repair help
            by Christos Tsiligiannis
            Hello to the forum.
            My name is Christos, I am new to the forum here and i am posting from Greece.
            So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
            To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
            So i tried asking for a schematic from the company and they would not give me one. Instead they...
            11-18-2024, 05:26 AM
