USB Dongle repair.
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    USB Dongle repair.
    Hi lads,
    I'm in a bit of trouble. While I was fixing a processor fan issue on a HP desktop PC, I inadvertently broke a USB stick that was stuck in the side of the PC when I turned it over. This USB stick is a dongle for a 3D design program so the guy needs it back working asap.
    I took the cover off it and, as I suspected, the 4 pin USB connections had been severed. So I soldered the four pins back on to the little circuit board, then plugged in to the USB to test. Next thing, smoke everywhere, so I plugged it back out again :-( An SMD capacitor evaporated before my eyes. This SMD cap was between the V+ and V- so I assume that it was just a filter cap for the 5v input to the main IC.
    http://omg.wthax.org/4EdbCp.jpg
    nb. There is nothing on the reverse side of the board.
    So I've soldered in a through hole cap 10v cap temporarily as a replacement (you can see the leads on the photo above), but I'm a bit concerned that it might explode again. I checked and double checked and I'm pretty sure that I connected the USB connector the right way (i.e. not upside down), so I'm not sure what happened to blow the cap in the first place.
    Any help or advice appreciated
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Re: USB Dongle repair.
    Okay small update. I put together a small circuit on a breadboard with a 5v source and a 4.7k ohm resistor. This should set the maximum current to about 1ma.
    http://omg.wthax.org/6NbaHS.jpg
    I connected the power source to the USB V+ and V- of the usb stick. There was a voltage drop across the resistor obviously so the voltage fed to the V+ and V- was 1.8v. I tested the capacitor and there was 1.8V across it.
    So it seems like there is no short on the USB board. But this still leaves me wondering why the original smd capacitor blew ?
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      mlcc cracked when the board flexed.
      then it shorted.
      replace and call it good.
      • JonathanAnon
        • Jul 2012
        • 457
        • Ireland
        Yeah that sounds like a more reasonable explanation than I can come up with. I've put it in and it seems to work. Just have to try to locate a good SMD 10V capacitor.
        • Kiriakos GR
          Banned
          • May 2012
          • 940
          • Greece
          The capacitor is not a critical component, you can skip it.
          I would solder on that PCB one 10Cm cable with a connector from a USB extension cable.
          And I would use hot glue so to lock everything with it original plastic package.
          This is just a key so to unlock the software, it can be plugged in the back USB ports, aesthetics are not an important factor.
          • JonathanAnon
            • Jul 2012
            • 457
            • Ireland
            Just an update:
            I was thinking the same way with regard to the usb connector, Kiriakos.. I cut the type A connector from an old phone usb cable, and connected the wires to the USB PCB.. I put the capacitor back on, then I cabled tied the little pcb into a small insulated plastic box. Dropped it back to the guy yesterday afternoon and it seems to be working fine..
            PHEWWWWWWW
            • Kiriakos GR
              Banned
              • May 2012
              • 940
              • Greece
                Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                I am comparing them to a brand new one that I installed
                The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                I going to let it run for several days before I remount back on the wall next to the...
                09-05-2024, 06:48 PM
                HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                09-12-2024, 02:30 PM
                HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                09-06-2024, 08:10 PM
