Cheap DIY Amplifiers
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Re: Cheap DIY Amplifiers
    What you mean? The misleading buttons? I was gonna throw it up on youtube, but I didnt want to have to fill out all the forms.
    I've just looked at it again, and I think you might be talking about the video quality. That's my fault, I just did a quick vid on my phone.. It's meant to be HQ video on my phone, but it completely loses focus when you bring it in close...
    • lti
      • May 2011
      • 2557
      There are tons of ads and the video takes a really long time to load. The video quality wasn't what I was talking about.
      There isn't a need to put on a different website like YouTube unless someone gets malware.
      The LM386 isn't a very good chip, but it works okay for headphones and higher impedance speakers (16 ohms or greater).
      • JonathanAnon
        • Jul 2012
        • 457
        • Ireland
        Okay, I'll load it on youtube in future.
        I've tried the 380N 14pin version and it sounds a lot better.
        • lti
          • May 2011
          • 2557
          Like I said in the above post, you don't really need to switch video hosts unless there are more complaints.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Originally posted by luke10050
            ive been using a 12v 1.5A power brick, i think its not so much the amp as the speakers, connected it up to a sony 8 ohm cabinet i have around and it sounded a million times better, so i really dont know.
            ^ THIS.
            1W of output power is actually quite enough when played through some proper speakers. If the speakers are ported properly, you can even get quite a bit of bass.
            Remember that in order to increase the output sound by 10 dB, the output power needs to be increased by a factor of 10. So let's say you have speakers rated for 80 dB/W (i.e. 80 dB with 1W of power). That means that with 10W, you'll get 90 dB, and 100W will get you 100 dB.
            I designed and tested a super-simple Class A amplifier a few months ago, and it was able to drive a pair of 8 Ohm Sony cabinet speakers at a reasonable volume despite only having a maximum output power of about 600 mW.
            Originally posted by ben7
            A switch mode power supply should be avoided because of noise from the high frequency switching.
            My dad's Sony TA-F70 amp uses a switching power supply. That thing was obviously designed properly, though, because there is absolutely no noise on the output.
            I myself have noticed that not all amps are sensitive to SMPSs. For example, the headphone amplifier I built which uses a Panasonic AN5272, doesn't care at all weather used on batteries or a cheap SMPS brick. It's noisy with both. I also have a pair of speakers that use a KIA6283A amp, and that thing is extremely noisy with SMPSs.
            However, the thing to know about most SMPSs is that if there are any "harsh" voltage spikes on the power line from nearby light switches, motors, or relays from appliances around the house, you will likely get a loud and nasty crackle noise on the output as well. Installing proper EMI and RF filtering and increasing the bulk input and output capacitance of the SMPS may help, though.
            Originally posted by mariushm
            A switching power supply will introduce some noise compared to a classic big heavy transformer but you probably wouldn't notice the difference with average speakers.
            The only problem with using a normal line transformer is that you also need big output capacitors (and those can be expensive). Otherwise, you'll get lots of line hum. I guess a way around that would be to use a linear regulator and waste a few Watts of power at the expense of clean output.
            • jinu_j
              How to test Subwoofer Amplifier with only a multimeter
              by jinu_j
              Hi Folks
              Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
              Problem
              I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
              Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
              Any advice would be appreciated...
              08-29-2024, 02:05 AM
            • UserXP
              Mackie CR4 amplifier no sound
              by UserXP
              Hi, people.
              I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
              Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
              10-17-2020, 05:06 PM
            • mikey5791
              Help on car amplifier only one channel works
              by mikey5791
              Hi all forum members,
              Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
              My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
              08-06-2025, 10:36 PM
            • Francesc V.
              Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
              by Francesc V.
              Hi:
              I've realized that one of the channels of this amplifier has no proper sound.
              This is the signal at the speakers output.
              As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
              Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
              07-15-2025, 01:33 AM
            • waspie
              Aiwa GX-770 Amplifier Protection Circuit
              by waspie
              I am by no means an expert on this type of troubleshooting but I can follow direction real well.
              I'm no stranger to using a meter and soldering iron so I'm looking for some help in fixing an old amplifier/system I got. This is part of a system "V-1200" by Aiwa where there are several components. My first problem seems to be the amplifier.
              It seems to be in protection. When first turned on I hear the inital relay coming on but never the second relay which is connected to the protection IC. I don't see any obvious bad components on the board. If I ground the...
              11-29-2022, 09:58 AM
